Need some cam advice for ported heads and a stock bottom end
If you don't know how many miles the used AI heads have on them, you should confirm the springs are in good condition and meet the requirements of whatever cam you get
Valve stem seals also
Village Troll
yes, use one on each side of the banjo. One between banjo and head and the other between banjo and banjo bolt head
These are similar to oil drain plug gaskets often sold in the "help" section of auto part stores. They were only a few $ at dealership when I last bought them
