Low Coolant Light I know this had been covered and I thought I did this properly.. I am a little confused when my low coolant light comes on and I let the car cool down I check the radiator and overfill there is plenty of coolant in there. Any ideas on what I should be doing differently? |
I am suffering from the same dilemma. I replaced the sensor with a fresh NAPA sensor, and I installed it perfectly with no leaks, nothing. I went out of my way to purchase an aftermarket bleeder valve for the thermostat hose which has a nipple to attach a small plastic hose to bleed coolant and better drain out air bubbles. I ran my car for a good half hour until I had no more air bubbles and that solved my low coolant light problem, for awhile... It came back on and I got so annoyed that I deliberately overfilled my reservoir to see if this might help, but I am seeing a daily coolant stain where the reservoir is and my light shows no sign of turning off. I am convinced I have a coolant leak or pressure leak somewhere, whether at the water pump seal or some bad hose I am not even aware of. At this point I am going to let it be until I am ready to take my car to a custom shop and have the whole damn thing restored and modified to like new. Right now, I need to work on my college schooling before dumping more money on my pit of a car. |
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp I recommend an AC-Delco sensor if you replace it. |
Originally Posted by shbox
(Post 19768210)
© 2024 MH Sub I, LLC dba Internet Brands
