What to expect out of 383 hotcam and boost rpm wise - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
Reload this Page >
Notices
Old 12-03-2017, 06:09 PM
Default What to expect out of 383 hotcam and boost rpm wise
Hi guys. I have a low compression 383, cnc'd lt4 heads, ported matching intake, and a vortech ysi. The car has pretty much all the supporting mods too (long tubes, dual 3" exhaust and more). In the past, even with the t trim, the power dropped off after 5000 rpm which is very unlike most centri blown cars. It wasn't detonation; power just dropped off.
My guess is that they put the springs that came with the hot cam in there and they just aren't enough for boost.
I read the thread on here a few weeks ago about what springs for boost so I'm guessing that I need something with around 150lbs of seat pressure.
My question is with the hotcam and the right springs and my displacement, what is a realistic operating range on this thing? Power being limited to just over 5000 rpm sucks because I can't spin the blower fast enough even with a small pulley. With the right springs, how high should I be able to spin this thing?
qwiketz is offline
Old 12-04-2017, 02:08 PM
With the proper dual spring in there 6000-6100 shouldn't be a problem. Spin the blower to max plus 5% at your cam's max rpm. How does your boost curve look? It can be a sign of belt slip.
Purple Poncho is offline
Old 12-04-2017, 02:51 PM
Thanks. Belt slip isn't an issue (at least not the main issue). The setup really is limited by how fast I can spin the motor due to the crank only being a 7.35". At 6000 rpm, that puts me at 55000 and the blower is capable of 65,000. With 5000 rpm, I'm only spinning it 46k.
The power falling off was consistent with the t trim and the ysi. The blower is making boost (about 14 psi) but it isn't translating into power.
I know that the stock hot cam springs are weak even for naturally aspirated motors. I'm hoping that maybe swapping these out will help bring car back to what a centri car dyno should look like. If I could get 6k, that would be good enough for now!
qwiketz is offline
Old 12-04-2017, 08:21 PM
Man-Crush Warning
Shownomercy's Avatar
Why not just get a decent cam in there?
Does not make sense to me to have a Ysi and a hotcam.
Shownomercy is offline
Old 12-04-2017, 08:39 PM
The car originally had a T trim when I got it. Found a deal on the YSI that I could not pass up . Eventually I'm gonna pull the motor out freshen up and then put a real cam in it. For now I'm just trying to do something to get it working somewhat propenly and without much downtime . I literally just got the car running correctly after five years this past week . I'm working more towards racking up miles rather than maxing out the performance . That something that could go on for almost ever.
qwiketz is offline
Old 12-04-2017, 08:52 PM
Man-Crush Warning
Fair enough.
Def get some good springs and lifters in there.
I am not sure where the limit is on cast cams and spring loads, may want to look into that before going crazy on spring choice.
Old 12-04-2017, 11:08 PM
Fair enough.
saw your post on springs:
You really want 155-160lb of seat pressure.
~2inch valve, with 10-15psi on it, is gonna take 20-30lb off your rated spring rate.
any idea what model will fit my lt4's? What lifters should I check out?
qwiketz is offline
Old 12-05-2017, 08:20 AM
Man-Crush Warning
Set your budget, cause lifters and springs are gonna vary from cheap to pricey.
Old 12-07-2017, 06:03 PM
What are your plugs and what are they gapped at? What is on the blower inlet? Rubber? I had 2 different issues with my car that is similar to yours it's just a 350...
pro94lt is offline
Old 12-07-2017, 10:14 PM
Good point. If you have a crappy rubber inlet you could be sucking it closed.
Old 12-10-2017, 09:49 AM
Would a PAC 1218x be a decent upgrade? Should I change anything else while I'm in there like add a rev kit?
qwiketz is offline
Old 12-11-2017, 07:35 AM
Yup, had an issue like that where at a certain RPM it would just not rev any higher, Put it on the dyno and saw the rubber boot sucking down.
moehorsepower is offline
Related Topics
Thread
Forum
Replies
Last Post
Louis
Forced Induction
13
02-01-2018 11:52 AM
fbody4everyone
1
11-03-2016 06:59 AM
JoeNova
PCM Diagnostics & Tuning
1
07-21-2016 07:13 AM
alaska_guy
11
05-31-2016 01:11 AM
snapdude
Manual Transmission
4
03-18-2016 09:34 AM
Quick Reply: What to expect out of 383 hotcam and boost rpm wise
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
