Heater hose routing diagrams needed!
Good evening.
I'm swapping a LT-1 based engine/motor in a NON-Chevy platform, and am trying to find "good" diagrams as to where each hose can go or be deleted.
I've found out the '92 Corvette has a water pump that looks like it lends itself more to a street rod application, without the additional porting.
Like this: https://www.nookandtranny.com/Info_LT1.html (at the bottom)
YES, I know it's a reverse flow cooling system..
I just don't want all those separate hoses/tanks etc taking up room, and keeping it as nice and neat as posible.
So, if those of you that have swapped the LT-1 into _____ and got it to run without overheating, post up pics or links showing what can be deleted or how the hoses can be routed.
Also, I am in the process of trying to contact the person of this vehicle that obviously has it figured out.
Thanks for your time.
E
E
Hope this helps.
Here is an image that might help:
https://www.camaroz28.com/forums/att...1waterpump.jpg
I think for a very simple set up you can use #2 and #5 for the feed and return to the radiator. I believe #1, #3, #4, and #6 can be capped off.
When I deleted AC in my old '97, I just connected #1 to #3 (heater hoses) with a small length of hose.
Here are some diagrams if you want them:
http://shbox.com/1/93-94_hoses.jpg
http://shbox.com/1/heater_hoses_93-94.jpg
