Any Kooks LT and Canton oil pan owners here?
https://www.camaroz28.com/forums/exh...0/#post6905815
Ditto, can't use the oil level sensor. I made a shorting plug to keep the light off. I didn't have to do any grinding to the Canton plug, but I don't have the Canton pan, I have the Moroso pan. It was very close....
http://www.ace1252.com/images/1996_L...s/DSCN4013.JPG
I would, but my builder or machinist was an idiot and made it so the dipstick won't fit past the main cap. Believe me, next time I need a rebuild it will have a dipstick. I was livid and tried to even grind down a dipstick and get it to fit. I had to grind it down so much it broke and I had to fish it out of the oil pan with a magnet.
Village Troll
Did you grind the tube or the actual dipstick? That's a common problem if going with aftermarket caps or 4-bolt. IIRC I had to grind about a 1/2" off the tube and strategically bend it to get it to fit.
