Severly overheated engine! What can I expect during teardown?
Severely overheated the engine on the highway, did not catch the idiot light till it was too late. Had white smoke coming out the back, smelled oil burning under the hood too. Temp gauge needle was pegged all the way to the right. After it cooled off, tried to start it and it wont start. Engine turns over so its not locked up, but sounds strange and also sounds like it has no compression at all.
Started the teardown last night and thus far I have not found the smoking gun. Oil pump drive gear is good and I did remember seeing oil pressure before stopping. Water pump drive gear is tight so I dont think the pump lost drive. New water pump was put on just this last spring, but still uncertain if its good or not. Will remove the plate and see.
Heads are in the process of coming off now and I fully expect them to be warped along with the gaskets destroyed. They will go to the shop right away for inspection.
So the big question, whats the likelihood there is damage to the block and rotating assembly? The motor does have forged pistons and rods and was extremely healthy prior to this. Also, the oil is still black and not milky, but of course smells burnt.
Is there any possibility I can get out of this WITHOUT pulling the motor? Or should I just go ahead and do it now? The motor really got hot, not a little hot but HOT. Also since I cant recall. Can the long tubes be left on when the motor comes out the bottom? Been about ten years since I have done this.
Thanks
Thanks
Village Troll
Everything connected to the engine can come out complete. I've always simply unplugged all sensors from the engine/trans and zip tied it out of the way instead of unplugging from the pass. kick panel and feeding the plug through the grommet on the passenger side. to me is six/half dozen and takes about as much time.
Thanks for the help guys. Still dont have the motor out yet. But maybe this weekend.
So far, I have determined that the water pump, t-stat are good. Oil pump drive gear is good too. So what else could cause a massive overheat other than low on coolant? That said, its possible that when I had the radiator out in the spring, I might not have topped off the coolant after bleeding the system. I just don't quite remember adding additional coolant to the water bottle.
Village Troll
Blown head gasket could have only breached a coolant passage to a cylinder so you could've burned coolant off to the point of becoming low and overheating. Check your plugs to see if one or more are cleaner than the rest.
I boiled off all of my coolant once, went into limp mode (runs on 4 cylinders) and drove it in 90* heat for 15 minutes home. I didn’t know what happened because when there’s no coolant in your passages, your temp gauge doesn’t read properly.
After I found the problem (incorrect heater hose plumbing) all I found that had failed was the seal on my brand new water pump. Fixed the routing, put another new pump in and fill it back up with coolant and drive it. I’ve been bouncing it off the rev limiter at the track for an entire year, no problems.
Village Troll
You have to unplug I believe two main connectors located in the passenger side "side" kick panel (not the one just below the glove box) and then feed those harnesses out into the engine bay. IMO that's more of a PITA than just disconnecting the sensors on the engine and trans. Takes about as much time, and with the age of these cars and how brittle **** is becoming, I'd rather leave well enough alone.
Okay the motor is out and on the stand.
There is damage to three combustion chambers on the heads:
Motor has ran strong since 08 with maybe 20K miles on it. Heads are ported so if this could be repairable, that would have to be considered. Taking them to my engine builder Monday morning. The shortblock looks pretty good overall. Cylinder walls, ring-land tops on the pistons all look pretty good. But it is likely, we will take it apart to be sure. Also, no coolant in the oil...no milky stuff on the dipstick.
So what could have happened here?
Detonation?
Bad gas?
Other?
I still cant rule out that it might not have had enough water in the motor. In the spring, the collant was drained and replaced and bled out properly. BUT I really dont recall topping off the bottle, after bleeding. In fact, I am pretty sure I did not. So maybe it was just very low and then all Hell broke loose.
Thanks
Detonation?
Bad gas?
Other?
Thanks
