Cooling Fans won't turn on. Completely stumped. So I have a 96 Camaro SS that the cooling fans will not turn on under any normal circumstance. So far I have replaced all 3 relays, the temp sensor on the water pump, and the fans themselves.If I jump the fan relays the fans will come on, so the circuit is getting power. I've tried wiring a manual fan switch in two different ways. I've done the right way by splicing into the circuit near the pcm and by taking the wires directly to the relays. Both ways are shown here in a different thread: https://ls1tech.com/forums/lt1-lt4-m...ch-how-do.html . I'm out of ideas of what to do at this point because I can't imagine how wiring directly to the relays wouldn't work. Any help would be greatly appreciated. |
Originally Posted by SLPSS254
(Post 19943438)
So I have a 96 Camaro SS that the cooling fans will not turn on under any normal circumstance. So far I have replaced all 3 relays, the temp sensor on the water pump, and the fans themselves.If I jump the fan relays the fans will come on, so the circuit is getting power. I've tried wiring a manual fan switch in two different ways. I've done the right way by splicing into the circuit near the pcm and by taking the wires directly to the relays. Both ways are shown here in a different thread: https://ls1tech.com/forums/lt1-lt4-m...ch-how-do.html . I'm out of ideas of what to do at this point because I can't imagine how wiring directly to the relays wouldn't work. Any help would be greatly appreciated. If you want the fans to turn on sooner the Hypertech programmer will allow you to do it, I think at temps 160 Fahrenheit and 180 Fahrenheit if memory serves me correctly. |
if you pull the plug of sensor on the front of water pump both fans should come on in a few seconds. That would show the stock wiring & relays, unless you already altered it, is working you can measure the resistance of the temp sensor using this chart to see if it is good. It may be bad feeding your PCM wrong info thus not turning on fans curtesy of shbox http://shbox.com/1/4th_gen_tech2.html#ect |
| All times are GMT -5. The time now is 03:00 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
