Lt1 383 stroker dying at wot.
Old 08-20-2018, 05:08 AM
Humphries94z's Avatar
Default Lt1 383 stroker dying at wot.
Lt1 dying at wot started running rough at idle. New plugs new coil newer icm. Figuring it’s the opti but wanted to get some info.when it dies it does start right back up. Check engine light comes on and goes off while driving.
Old 08-20-2018, 05:26 AM
Greg88's Avatar
Did you use a scanner to determine what the code was for the engine light?
Old 08-20-2018, 06:03 AM
Have not yet. Do not have a cord currently. I’m trying to get one now.
Old 08-20-2018, 08:51 AM
Village Troll
SS RRR's Avatar
Check fuel pressure. Your pump may be on its way out.
Old 08-20-2018, 10:24 AM
Wouldn’t it spit and spuder like it’s running out of gas? This dies like someone shut a kill switch off
Old 08-21-2018, 12:51 PM
BALLSS's Avatar
Originally Posted by Humphries94z
newer icm.
how "newer"...and what brand?
typically a failed fuel pump the motor sputters/stumbles first then dies. Certainly check FP just to rule it in/out as the problem. If good move on to ignition.
immediate shut off is likely ignition...ICM, opti or coil...or wiring going to them
Old 08-21-2018, 01:56 PM
Msd coil pry 2-3 weeks old, icm is pry a month old.
Old 08-21-2018, 02:09 PM
BALLSS's Avatar
is it a AC Delco ICM?
Old 08-21-2018, 05:09 PM
No oriley special 91 bucks lol. I know I should spend the money on a delco
Old 08-21-2018, 05:17 PM
BALLSS's Avatar
well I would not rule out the ICM then...
Certainly AC Delco anything can also fail....just off brand stuff has a higher fail rate
Old 08-21-2018, 05:18 PM
When it does it it’s like someone turns a power switch off. Engines dead right now! No spitting studering quits now
Old 08-21-2018, 05:36 PM
Village Troll
SS RRR's Avatar
Now that it's dead, you can do a test to determine if the ICM/coil are getting a signal. Have you looked into the condition of your opti harness?
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old 08-21-2018, 07:14 PM
No no sorry. Engine is not dead it runs. Just dies under wot sometimes.
