Another no start LT1
Tests done:
No pulsing ground at the injectors.
Optispark harness has both 5v references, 12v battery voltage, and 0-1 ohms ground.
At the ICM harness it's being weird. Terminals A and D both have battery voltage. Terminal B... the first time I tested it had AC volts while cranking (about 2v AC). Now it has 0. Terminal C... the ground is also acting very strange. I've tested it several times. Sometimes it has 0 ohms to ground, sometimes it has 15-20 ohms to ground. This is with the key off of course.
All fuses checked and work fine.
EDIT: Should add I tested for fuel and have it with a fuel pressure gauge.
I took a spare opti and did the drill test. Key on engine off. I spun the spare opti with the drill and still didn't didn't get spark or injector pulse.
EDIT2: Just noticed my PCM ground to ground and battery ground to ground are also giving funky readings. Bad battery or bad battery cables?
No crank....
http://www.ace1252.com/1996_Z28_Fact...hots/No_start/
Crank, but no run....
http://www.ace1252.com/1996_Z28_Fact...ut_no_run1.JPG
http://www.ace1252.com/1996_Z28_Fact...ut_no_run2.JPG
http://www.ace1252.com/1996_Z28_Factory_Manual_Snapshots/crank_but_no_run3.JPG
https://www.testequipmentdepot.com/a...ge-drop_an.PDF
I removed all the under hood grounds (2 on the passenger side of the block, the one on the head with the coil, the one with the strap, the two by the headlights, the one by the jump post, and the battery terminals themselves) and cleaned the ring terminals and bolts/nuts up with a wire brush and even re-ground bare metal on the 4 chassis grounds (the one for the ground strap near the air filter, the one on the driver's side above the headlights, the one on the passenger side above the headlights, and the one by the jump post). I haven't tested it yet because I need to make trip to the hardware store plus I think I'm going to clean up the positive ring terminals as well.
After cleaning all the ring terminals, bolts etc I got it to be 0-1 ohm at the battery negative to chassis ground. I still couldn't get 1-4v AC at the ICM or get injector pulse though, even using a drill to spin a second opti. Then I noticed it went back to 18 ohms to ground ONCE but then back to 0-1 ohm. I'm wondering if I have a slightly but not completely broken wire or bent terminal pin somewhere. Frustrating. I have a scan tool coming tomorrow so I'll see if it stored any codes.
No 1-4 volts AC when cranking puts the problem between the opti and PCM according to the buick know how opti vid. Timestamp below where they speak to that point. Edit: timestamp is 17:25.....can't disable this video embedding that breaks the timestep link.
Since this is so strange it has to be an open circuit (or the PCM) at this point since even the spare opti won't do anything... I had previous checked terminals A, B, C, and D on the PCM side of the harness to B2, B20, B14, and B3 on the PCM. All checked out fine. But then I have a spare opti side harness (for spinning the spare opti) and I tested B2, B20, B14, and B3. They were bad so I tested the short harness and terminal A at one end works with terminal A on the other etc. I took the OEM opti side harness and backbrobed. Same deal. Very spotty connections between one end of the connector and the other!
Side note: after cleaning the grounds the car cranks much better, lol.
