ratchet Shifter recommendations
Old Jun 26, 2020 | 09:21 AM
ss27gogeta's Avatar
Default ratchet Shifter recommendations
looking at putting a ratchet shifter in my car it is a 95 trans am. what will fit in our cars from what i understand no one makes one that is a direct fit for a 4th gen f body. main reason for the ratchet shifter is. i am going to be needing a new transmission sooner rather than later and will be going with a full manual valve body when i do thanks.
Old Jun 26, 2020 | 12:26 PM
AgFormula02's Avatar
Have seen some nice installs using a M6 boot.
Old Jun 29, 2020 | 08:28 PM
David94TA's Avatar
I used a B&M Quicksilver shifter when I had the 4L80E (manual valvebody) in the car. Mounted it on the transmission tunnel and had it coming up through the 6-speed shifter boot (car was a 6 speed originally). Looked great. I did not use the housing that came with the shifter--just the shifter body. Only thing is that you don't have an gear indicator.
