94 T/A 5.7 won't start
Old Oct 25, 2020 | 12:09 AM
Gene Montoya's Avatar
Default 94 T/A 5.7 won't start
Omni spark, coil, wires, plugs, all new. Theres Fuel to the rail. Firing order is correct to omni
??? Any suggestion
Old Oct 26, 2020 | 08:06 AM
Z28Roxy's Avatar
Are you getting these results:
http://shbox.com/1/4th_gen_tech2.htm..._testOptispark Harness
A = ~5vdc
B = ~5vdc
C = ~12vdc (or your system voltage)
D = ~0 - 0.2 ohms ground with key OFF
ICM Harness
A = ~10vdc-12vdc (or your system voltage)
B = 1vac-4vac while cranking
C = ~ 0 ohms to ground with key OFF
D = ~10vdc-12vdc (or your system voltage-might be slightly less than reading at "A")
http://shbox.com/1/95_ign_system_schematic.jpg
