Delete O2's With LT1Edit?
Old Dec 8, 2004 | 03:06 AM
NitrousJunkie's Avatar
Default Delete O2's With LT1Edit?
I wanna take off all my Emmisions crap and o2's behind the cat, can I do this with LT1edit? or so I need to send my pcm in?
Chris
Old Dec 8, 2004 | 05:50 AM
METALBEAST's Avatar
What year is your car. If you have a 94-97, you need to get some O2 simulators. You can pickup a set from Summit Racing for about $80.
Old Dec 8, 2004 | 09:28 PM
TwoFast4Lv's Avatar
Yes you can eliminate the look up tests for O2 sesors with LT1 OBD-II Edit. this only applies to 96-97 cars. 94-95 car do not have O2s behing the cat Not even the duel cat 95 cars
Old Dec 9, 2004 | 06:54 AM
METALBEAST's Avatar
Thanks Twofast For those who don't have the LT1 edit program, you can use the O2 simulators on your 96-97 for bolton applications. I used them when I had my 97 Z. I guess in your case your pretty modified Nitrousjunkie
Old Dec 9, 2004 | 07:37 AM
BRENTT94Z's Avatar
TwoFast is correct, If your sending the PCM in to have it tuned,
Theirs no since in wasting the $40 for sims. They shouldnt charge you any extra to delete the rear 02's. Only OBD-2 (96+
