Cam ? for a buddy's 96 LT1 A friend of mine got a comp 07-502-8. What is this cam like. Any lope to it? How much power? stuff like that. He has Hooker LT's, ORP. Anyone running this cam is it any good? Thanks |
Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 1,500-5,500 RPM Intake Duration 050 inch Lift: 218 Exhaust Duration 050 inch Lift: 224 Duration at 050 inch Lift: 218 int./224 exh. Advertised Intake Duration: 269 Advertised Exhaust Duration: 276 Advertised Duration: 269 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.495 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.503 Valve Lift with Factory Rocker Arm Ratio: 0.495 int./0.503 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: No Grind Number: LT1 XR269HR-12 Quantity: Sold individually. Basically its a pretty small cam, small lift, short duration, with a 112 LSA. it will thump, but thats about it.....its a tiny baby cam and I would highly reccomend going bigger, even for stock heads. |
| All times are GMT -5. The time now is 06:01 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
