pulley swap
get your own name ricardo your not dravenmyers
you know this you *** clown now you are the one that should get a name change to slowplanchaoZ27 cause I dont know were you came up with fastjoe you little ho
.I dont know why you waste these peoples time by posting how to replace a pulley.Whats next how do I check my oil?,like I said if you do really have a pulley set give me a call when this stupid rain stops and we will put it on faster then your car does a 1/4 mile. Trending Topics
however if you have also installed a tornado air and believe there is power to be found from putting a tiny bit smaller pulley on a car with stock internals then here is what you need:
a ratchet set
a 3 bolt pulley puller thing (or just start banging it with a hammer and working it back and forth)
and thats about it...
take your crank/balancer pulley off of the hub, put the new piece of **** on the hub, put your old crank/balancer thinggy on the new crank pulley, use the extended bolts to bolt it back on and then put your belt on.... shouldnt take too long
