BMR questions
Old Mar 28, 2005 | 12:04 PM
scotts94_z28's Avatar
Default BMR questions
1) On the lower controls arms which is better, the poly/rubber or just poly for a daily driver in the summer and see's the track about once a month?
2) Do the bolt on lower control arm relocation brackets fit the f-bod 10 bolt since it doesnt specify car makes it fits?
3) Are their subframe connectors any good?
PS. All of this stuff is going to be tubular not boxed
Old Mar 28, 2005 | 12:23 PM
AAron's Avatar
i had the LCAs in poly/poly and they worked great.
the relocation brackets are only really useful if you have a lowered car, and as far as i know they will fit most any rear end. they fit on the mounting points not the axle tubes.
i only had their boxed ones, but they where really nice on my T-top '98 z28.
i just read your sig you already have most of that stuff. it wouldnt help much at all if you changed to the BMR stuff over what you have currently.
Old Mar 28, 2005 | 01:55 PM
the sfc and lca in my sig have been sold to a friend for more then i payed for them thats why i am looking at this stuff since he wanted them immediatly
Old Mar 28, 2005 | 02:11 PM
AAron's Avatar
right on. then yeah BMR stuff is great
Old Mar 28, 2005 | 02:12 PM
Formula94's Avatar
I have the SFCs, LCAs (poly), relocation brackets, lowering springs, and adjustable panhard bar; all from BMR and all tubular, and I really like them. Even if you don't have the car lowered, the relocation brackets will help eliminate wheel hop. And yes, you can use them on the 10 bolt.
