LT1 Dyno Archive
Old Mar 20, 2008 | 10:53 PM
  #261
James Montigny's Avatar
Originally Posted by Sick-1
forged 383
le3 heads/cam
hooker long tubes
58mm
tnt kit
419 rwhp
550 rwhp on spray
crap track time 12'03 at 120.8 mph with a 2.1 60ft
on motor, dont have enough tire to even try the spray yet
Did you get that tuned?
Old Mar 20, 2008 | 10:56 PM
  #262
Sick-1's Avatar
ya trailer to fort worth to have it dyno tuned
Old Mar 31, 2008 | 11:09 PM
  #263
Storms of War's Avatar
Originally Posted by engineermike
It annoys me when people post up a bunch of excuses with the dyno numbers. If you don't think your results are valid, then don't post them.
What's worse are all the people who say "check the sig", because they're too damn lazy to copy and paste their signature into their post. This way, when they get a different car or change their signature the numbers and mods are no longer listed in their sig and you're left with no clue as to what power they made, what numbers they ran or what mods they had. That's happened about 10 times in this thread.
Old Apr 4, 2008 | 03:57 PM
  #264
Red93z28's Avatar
93 z28
Stock Ported Heads w/ bigger valves
280XFI Comp Cam w/ 1.6 Rockers
30lb Venom Injectors, BBK 58mm TB
Mac Headers n y-pipe, gutted cat and slp loudmouth
389rwhp, 376rwtq on the dyno after tuning.
Old Apr 4, 2008 | 08:48 PM
  #265
jaysz2893's Avatar
Bone Stock i was 266/314 M6 with 3.23 rear
After a cai, underdrive, tb bypass and tb foil, PCMforless tune i was 303/341 and ran 13.2@103 with a 2.01 60'
Now i have same bolt ons with LT headers and borla with cutout and i went slower at the track?!? WTF
Old Apr 7, 2008 | 01:24 PM
  #266
phirepower's Avatar
402rwhp 378rwtq theres a little more than whats in my sig Don't ask, won't tell. No Nitrous, turbo, supercharger. Full valvetrain, geometry of my own design.
Old Apr 11, 2008 | 03:20 PM
  #267
Shaine's Avatar
95' lt1 brand new GM perf. trans. 3,600 stall, Factory lt1 short block port and polished heads match ported to a ported intake manifold, thats also match ported to 58mm BBk, huge front mount, 3 inch tubing, turbonetics turb, msd ignition, ( 6AL, coil, and BTM) 44lbs injectors, traction bars,...and a jegs sticker
Old Apr 11, 2008 | 04:59 PM
  #268
engineermike's Avatar
Call me crazy, but I don't see dyno numbers in there.
Old Apr 11, 2008 | 10:38 PM
  #269
integraxtc's Avatar
I think you guys should start posting what type of tire you guys are running on?
slicks, dr, or street?
Old Apr 14, 2008 | 10:58 AM
  #270
OutlawZ's Avatar
new dyno numbers:
529 RWHP/505 RWTQ
naturally aspirated 383 ci LT1 12:1 CR, 227's, solid roller cam, shaft rockers, single plane, accufab TB, TH400, 4500 stall, 9" Moser rear, 325/50/15 MT DR's on 15" bogarts. FAST XFI standalone, 50lb injectors, 10AN feed, 6AN return Nasty performance sumped tank with Weldon 600A
Old May 4, 2008 | 03:48 PM
  #271
real82it's Avatar
A4
Stock intake
Stock heads
Intake and heads port matched and polished
SCAT 4340 Forged Crank
SCAT 6" H Beam Rods
JE Forged 170817 Pistons - ~9.5.1 compression
Total Seal rings
Comp Cams 576/570, 230/236, 113 lsa
Comp springs
Comp Cams lifters
Canton pan
Summit 58mm throttle body
Melling MEL-10552C
Pacesetter LT headers
Magnaflow Hi Flow Cats (converted to duals)
Dynomax muffler
ATI 600B at 6lbs (that is ALL this SC will make with this set up....fyi)
I added a graph as an attachment that compares my stock 350 LT1 to the 383 I built with the same supercharger at the same boost level.
449RWHP and 468 RWTQ.
Old May 6, 2008 | 09:04 AM
  #272
Green3spd's Avatar
Went to track Saturday, this is my first M6 and my first pass with a M6 car...
1000ft-11.42 @ 93
1/8th-8.98 @ 81
How does that sound with my mods...
K&N CAI, Elbow and a Magnaflow catback...
Old May 10, 2008 | 01:26 AM
  #273
MadMike 97 Z28's Avatar
MY HP/TQ NUMBERS
Max Horsepower............... 275.76 @ 5300 RPM
Max Torque..................... 316.85 @ 3200 RPM
mods at the time were
-K&N CAI
-SLP TB air foil
-SLP manual fan switch
-GM 1LE elbow
-SPEC stage 2
-18X8.5 wheels
Old May 11, 2008 | 02:08 PM
  #274
blownbird355's Avatar
Was that with a FMU?
Originally Posted by LT1SC95Z
557 RWHP
593 RWT
Numbers are before the tune, and before the proper injectors and new trans were in (the old one was slipping) and before the new throttle body went it.
12 bolt rear,3.73 gear,17in C5 rims, 275 BFG TA Drags, 462 lift long duration cam, new lifters rockers pushrods, CAI, BBK Short tube headers, Muffler delete, Polished throttle body, 32lb injectors, New spark plugs, 3 1/2in aluminum driveshaft, vigilante torque converter, new trans with shift kit (out of 96 automatic) Procharger at 9psi---other small mods
Old May 16, 2008 | 12:07 PM
  #275
jarendt31's Avatar
383, lightly ported heads, CC306 cam, 58mm TB, PS LT headers, true dual 3" spintechs, MSD 6AL, MSD coil, 4.10 gears and a custom dyno tune.
380rwhp and cant find the dyno sheet to get the torque
Old May 18, 2008 | 05:48 AM
  #276
MY99TAWS6's Avatar
I am wondering if anyone has a combo similar to my mods. I have not finished up yet do to not being able to decide between LE2 heads and the new AFR 180 eliminator heads.
I have 3.42 gears, 2800 vig stall, asp underdrive, 30 svos, jet tuning, magnaflo catback, 52mm bbk tb,CAI,
have CC305,1.6 rockers,Mac mids,no cat and as said my head choices are LE2 or AFR 180 elminators. So anyone got something close to this? Wondering if can hit 360 rwhp with the above mods.
Old May 30, 2008 | 07:08 AM
  #277
jsds500's Avatar
11.50 @ 119
1.63 60ft
93 TA stock heads and bottom end.
1.6 RR
BBK 58mm TB
Vortech supercharger intercooled 8-9 lbs (dyno'd 419 w/6lbs)
Vigilante 2800 stall
3.73 12 bolt
Hooker long tubes
Borla cat back
probably missing something
Old Jun 3, 2008 | 01:30 PM
  #278
blk94z's Avatar
Completly stock ran a 9.00 in the 1/8th. I need to get me some track time now. I have a cam and i am putting in longtubes next week.
Old Jun 11, 2008 | 04:50 PM
  #279
brucealmighty744's Avatar
1994 trans am lt1 M6
MODS:totally stock...it is pretty much bad *** lol. mods will come soon. I see all of these numbers on here and I was wondering how much rwhp an lt1 fbody has to begin with. I know what it is at the crank....but in order to see the gains I was hoping you guys could enlighten me. I do at least have newer rims on my car(my one mod), that has gotta be at least another 15-17 ponies lol...oh, i forgot, that only works for ricers.
Old Jun 18, 2008 | 10:57 PM
  #280
NorthernZ's Avatar
I dynoed out at 313hp and 315ft. Had a ignition stumble after 4800 that I think affected the over all numbers but I think it's with in 10hp? We only ran the car to 5700 so i don't know what it could of been but it's a start.
The computer hasn't been done yet but I'm not gonna do it until next winter when I put the heads on it. Any guesses what a computer tune would do.
