1.6 RR Clearance
Old Apr 11, 2005 | 05:17 PM
WhiteBlur's Avatar
Default 1.6 RR Clearance
When my engine goes back together, I well be installing 1.6 RRs. I was told by acouple of people I work with it's a good idea to run stud girdles (I dunno if that's how you spell it) because the rocker nuts like to back off. Do I really need them or can I go without? And what can I do about the clearance problem? I have yet to find covers that are higher and have the notch for the alt. Also, I was told before that some brand makes an adapter that makes it where you can run covers with the outer bolts. I know a lot of people on here are running 1.6 RRs, so what did you do about this problem?
Thanks!
Old Apr 11, 2005 | 05:23 PM
dhdenney's Avatar
I have 0 issues with my 1.6's. I have the Crane Gold Race rockers that are self aligning. I do not run guide plates or stud girdles and haven't had any problems.
Old Apr 11, 2005 | 05:29 PM
WhiteBlur's Avatar
So the stock valve cover have the clearence for the rockers? Would a cam make clearence a problem?
Old Apr 11, 2005 | 06:11 PM
buffman's Avatar
Yes Most aftermarket 1.6 Rockers clear the Stock Valve Covers just fine. A little tweaking is required sometimes for the wider body pro magnum rockers from Comp Cams. From doing some reading Some people have had problems w/ Non-Self Aligning Pro Mags loosening the rocker nut, but I haven't seen a case of anyone complaining about S/A pro Mags or similiar brand loosening.
Just give that poly lock a good wrenching and it shouldn't come loose. You could always apply a dab of blue (low strength) loctite to help keep them tight. I've seen some people recommend tightening the rocker nuts to proper load and then backing off 1/8 turn, and while holding the rocker nut tighten the poly lock. When it becomes tight, remove the wrench holding the rocker nut and retighten the rocker nut 1/8 turn via the poly lock. Or something along the lines of that
Matt
Old Apr 11, 2005 | 07:17 PM
dhdenney's Avatar
Not for the rockers and valve covers. Just stick to self aligning and you shouldn't have any problems. 1.6 is fine for stock covers.
