When Installing a Cam?
Old Apr 14, 2005 | 08:07 AM
Dranzer350's Avatar
Default When Installing a Cam?
Hey guys I have a simple question most of you can probley answer for me. When installing a cam is there any other parts you have to change an if so could you plz tell me what im kinda of getting my self into before I do somthing and not have all the parts.
Old Apr 14, 2005 | 08:21 AM
Dranzer350's Avatar
If you guys can tell me who makes the cc305 cam and where i might be able to find it an what is price range on it Thanx.
Old Apr 14, 2005 | 08:45 AM
N20LT4Bird's Avatar
comp cams ......get it anywhere. like......
http://thunderracing.com/catalog/?ac...&vid=4&pcid=51
Old Apr 14, 2005 | 09:15 AM
AdioSS's Avatar
valvesprings
Old Apr 14, 2005 | 09:31 AM
Blackbirdws6's Avatar
lifters arent a bad idea while ur at it, but you may not want to go that far.
Old Apr 14, 2005 | 10:57 PM
Crazyz28's Avatar
timing chain
Old Apr 15, 2005 | 01:12 AM
GhostZ's Avatar
What do you HAVE to change along with a bigger cam. About the only thing you need to upgrade will be the springs as AdioSS already said.
Of course you can go for the gold like I did when I did heads/cam....that little bit turned into a lot with P&P'd heads/intake, RR's (which I already had when I did my original Hotcam kit), Comp R lifters, hardened pushrods, GTP-6 cam, CC987 springs, electric WP, Cloyes timing chain, Delteq, etc....so then you add those and the other things like gaskets, plugs, cam lube, RTV, oil, antifreeze and maybe a few bucks here and there if you break a part or need something like the fuel line disconnect tool. All the little things add up in a hurry!
But what would you absolutely have to upgrade....just the springs.
