Stall and Nitrious?
Old Apr 27, 2005 | 02:54 AM
1bottled93toenvy's Avatar
Default Stall and Nitrious?
ok so im looking for a next mod(s)..and im think a 3600 stall and a nitrious kit..do u guys think thats good mod list considering my mods...which are really not much...or should i be looking at a cam and headers...or something else??? my car is a 93 with 80K........or should i go full suspension to get the power i do have to the ground???
Old Apr 27, 2005 | 10:07 AM
Aries's Avatar
a convertor and gas will be a great advantage to you. With the 3.23 gears you shouln't have too much of an issue planting the rear, but some suspension upgrades will be needed soon. Especially if you plan on going to a 3.73 or 4.10 gear.
Old Apr 27, 2005 | 01:24 PM
yea...well i thnk at most i would go 3.73 gears, and i was thinkg getting some LCA's and some other things....and would lowering my car be worst for racing>????..ive heard that it is??
Old Apr 27, 2005 | 05:33 PM
chevy94c's Avatar
You will like the stall and spray. I know i do.
Old Apr 27, 2005 | 05:44 PM
Saad06's Avatar
personally...i would do spray/stall first... you need a stall to get the max out of a cam.. so do the spra/stall... then get cam/headers... and you have a race car.
Old Apr 27, 2005 | 06:57 PM
so u thnk go stall and spray and not go suspension firsst?????
Old Apr 27, 2005 | 07:09 PM
BizZzatch350's Avatar
Moderator
You wont have to go to radical on the suspension, lot of cars run great on not so wild suspensions. Get that converter, gas and tires, should run great
Old Apr 27, 2005 | 08:55 PM
rebersole2's Avatar
In my opinion, I would look into the camshaft and the converter first. After a while when you can get the gas, headers, gears and tires, you will appreciate that the cam and converter are already done.
Old Apr 27, 2005 | 09:19 PM
WhiteBlur's Avatar
A stall is like one of the best things to can get for an auto, so that's a given. And i'd go with the spray too, you'll love it.
Old Apr 28, 2005 | 06:56 AM
skinnies's Avatar
Get a good set of tires(m/t drag radials ) and it should run good with the stall/spray.
Old Apr 28, 2005 | 02:10 PM
Formula94's Avatar
Make sure you get a stall designed to work with nitrous. PI will set you up with a stall that is built to your current/future mods. That's what I did, since I plan on spraying later on this summer, and then building a high comp bottle baby.
Old Apr 29, 2005 | 10:20 PM
i have a set of Nitto Drag Radials..245 50 16
Old Apr 30, 2005 | 12:09 AM
chevy94c's Avatar
You should be all set with those tires, Just heat them up.
