What intake gaskets are you guys running ?
Originally Posted by Z8'S
Yes you can they are about 15$ a piece, pricey but they are what you need make sure you get 2 they come one to a package. I use 3m weatherstrip adhesive around the ports to seal them . Never have problems. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Cool thanks.
Where do i buy this weatherstrip adhesive ? Are you using a thin bead around the ports ? On the top side of the gasket. Or both.
Is This adheasive any better than the normal stuff we use to seal our intakes.
Originally Posted by monster7
i have stockers and also have seen them on the trick flow heads without issue also
i dont know what the port looks like on the gtp's
so i dunno if they will work on them
but they dont have a metal seal ring so they can be trimmed without issue
Originally Posted by 96SCTA
Cool thanks.
I put it around all the ports on the head and intake and both sides of the gasket.
I have run 24+lbs of boost with no leaks
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
the 1284's dont have a seal ring on them so they can be trimmed without issues my heads are milled .030 and my intake is not touched and they still seal without any sealant or rtv.
and my bad on the size of the ports i didnt know they was that much larger.
You can get the weatherstrip adhesive from most auto parts stores .
I put it around all the ports on the head and intake and both sides of the gasket.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I have run 24+lbs of boost with no leaks![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
NICE !!!!!!!
What do you use to seal your intake with . Black RTV ?
Im worried that it will not hold up to the boost !!!
Last year I was only running between 9-12psi. The black rtv held up.
But im not sure how well it will hold up above that.
Thanks Again
Micah
NICE !!!!!!!
Thanks Again
Micah
Thanks Again
Micah
#32
Ok guys thanks for your help.
I cant wait to get this motor together.
Any of you guys using header studs ??
Im thinking about trying them out,
#35
So whats up with you Tom ?? whats new ? whats old ?? lol
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Sounds like a mean monster you're going to have there when you get it all done. You're going to have to post up some pics for us folks of modest means
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Tom
