LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Look at what I've been doing... (https://ls1tech.com/forums/lt1-lt4-modifications/358785-look-what-ive-been-doing.html)
NXSLT1 Jul 31, 2005 03:38 PM
Here's a couple of pics of the 9" I've been working on. Gotta finish welding the brackets and make caliper brackets, won't be long now!!
http://www.geocities.com/mastertone50/07-30-05_2138.jpg
http://www.geocities.com/mastertone50/07-30-05_1932.jpg
72chevy2 Jul 31, 2005 06:01 PM
Lookin good - obviously takin the cheaper way rather then shellin out 2200 bucks for a new one
Good work!
NXSLT1 Jul 31, 2005 08:49 PM
Exactly, I aint paying that much money for something I can do myself. Plus I really enjoy building stuff. I've got $1150 in it, that's the axles, gears, locker and few small things. I'll be glad when I'm done with it so I can drive the car again!!
72chevy2 Aug 1, 2005 07:53 AM
It'll be fun to give it all the hell you want once its together.... I smell hard street launches in the near future
AAron Aug 1, 2005 09:57 AM
are you beefing up the LCA mounts on the body?
Shon Herron Aug 1, 2005 09:57 AM
Using the PeteZ bar type set up so no TA going to be used?
Let us know how it does!
NXSLT1 Aug 1, 2005 06:47 PM
Nope I won't be using a TA and no I won't be beefing up the body mounts. Might have to in the future, we'll see. The motor will be the next project after I get done with the rear.
Shon Herron Aug 1, 2005 09:09 PM
Keep us or at least me posted!!
Valkyn Aug 1, 2005 09:51 PM
Eager to see how it works out for you.
The torque arm mount is the biggest obsticle in modifiying a rear to work in our cars, if this setup works well that could be eliminated.
Hope it works out for you, but usually when something sounds too good to be true...
NXSLT1 Aug 1, 2005 10:12 PM
I don't understand why you think it's too good to be true. Several people are already running this setup (Pete Z bars) I just made mine instead of buying them and they are a lil bit beefier than those. I really want a 4 link but there just aint enough room for that without backhalving the car, that's not an option.
I'll keep you posted. I got all the brackets welded up today and it's starting to look like something now. Soon as I get the milling machine running I'll be making aluminum caliper brackets and then I will be done, finally!!:eek2: I took a few pics along the way and will post them on my webshots.com page when it's done.
AAron Aug 2, 2005 09:54 AM
i was looking and i figured out a way to 4 link it but you loose the back seat/and speakers. and there is a lot of fab work.
Valkyn Aug 2, 2005 10:14 AM
I don't understand why you think it's too good to be true. Several people are already running this setup (Pete Z bars).
I really hope it does work well, do you have any more info on the Pete Z bars?
This could really save alot of money if it worked well, not having to buy an $2000 12bolt/9'' and then not having to buy a $600 torque arm.
Shon Herron Aug 2, 2005 11:47 AM
Pete Z bars (or types like those) are sold thru Jegs and Thunder and probably a few other sponsors.
Rob 94Hawk 319 Aug 2, 2005 01:18 PM
Any sites or any literature behind the theory of the Pete Z Bars? (Spring rate changes, geometry changes, etc... )
Shon Herron Aug 2, 2005 01:21 PM
I think Steven, Sar2k, runs them. He should be able to be found here or Thunder.
I think madman has used them on some cars.
It is going to be tough to get information about them b/c not alot of people run them.
Shon Herron Aug 2, 2005 01:26 PM
here are some mentioning of them:
https://ls1tech.com/forums/showthrea...ht=Pete+Z+bars
Gosh, there are 33 post from a search just as you could do.....
Rob 94Hawk 319 Aug 2, 2005 01:26 PM
Thanks Shon, I'll give a yell at Steven if I get a chance.
NXSLT1 Aug 2, 2005 01:30 PM
Not sure but seems like I read somewhere that madman reccomends leaving the TA on with his setup in case something breaks. You have to take the front end of the TA out of it's mount and box it in to keep the suspension from binding. This is why mine are a lil beefier than his because I won't be using a TA.
Shon Herron Aug 2, 2005 01:31 PM
i thought that the TA still had to be mounted to the rear/TA mount near trans for some sort of locating but it was ran loose and probably was noisy but others that actually have one might (would be!) better to ask...
NXSLT1 Aug 2, 2005 01:39 PM
Not sure exactly how they do it because I've never seen it, this is just what I've read.
© 2026 MH Sub I, LLC dba Internet Brands
