LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   What do I need for 12's? (https://ls1tech.com/forums/lt1-lt4-modifications/435497-what-do-i-need-12s.html)
Camaro 0wner Jan 11, 2006 09:15 PM
Well, I think I'm almost there. I haven't run in the quarter yet, but I want to know what should put me in the 12's for sure. I just ran an 8.4 @ 83.7 with a 1.975 60'. I know I can improve on the 60', I spun a bit. I actually had a run with a better 60', but I had to let off on that run. I think my 60' was a 1.939 or something...I'll have to check the time slip. I think I would have ran an 8.3 on that pass. Anyway, my car dynoed 284Rwhp and 312lbs of torque. What do you guys think? How close am I to 12's?
What next mod can I do that would get me in the 12's, (If I'm not there) that wouldn't be extremly expensive. I don't want to spend a whole lot. Thanks for the help.
I have a 94 Z28 with just LT headers, Matching Y-pipe, LT4 KM and a Moroso CAI.
METALBEAST Jan 11, 2006 09:43 PM
http://www.wallaceracing.com/eigth-t...conversion.php
According to this you would have run around a 13.2ish. You're really closeIf you could get you're 60' down just a tenth, that would knock off another 1.5 tenths off your quarter. Have you tried running some stickier tires?
Camaro 0wner Jan 11, 2006 09:51 PM
I have some nitto 275/40/17's. (I have that size tire all around) They grab pretty good, but I haven't really got a lot of practice. I ran that time on 1 run. My other run, (that I was mentioning, the 1.939 60') I had to let off towards the end of the track. I had a better 60', better 330 and slowed down, because the car I was racing was swerving. I never got another race in.
I'm also not reving the car up at all. I just hit the gas when the light comes on.
METALBEAST Jan 11, 2006 09:53 PM
What was the DA like at the track that night? If it was not that good, you might try running on a colder night with your car cooled down a little more. Only problem is if it is TOO cold the track won't hook very well.
Formula69 Jan 12, 2006 12:46 AM
jay my old firebird weighed 3300 lbs, put down 317 hp and 340 tq and i ran a 12.55@111 with a 1.68 60 ft so your pretty close.. try to get the weight down because that helps a lot
Speed Density Jan 12, 2006 12:53 AM
I dont think i can touch 12.s here without a power adder, etc N20 h/c. I want 12.s dag nabit.
METALBEAST Jan 12, 2006 06:21 AM
What is the elevation there?
Speed Density Jan 12, 2006 09:57 AM
2700!! Boise, ID.
Camaro 0wner Jan 12, 2006 10:13 AM
What kind of weight reduction can I do? I want to keep my back seats. They don't really weigh much anyway...
BigKap94z Jan 12, 2006 10:46 AM
Do a converter man!! Fuddle is running a special right now, $50 off. Check it out.
Camaro 0wner Jan 12, 2006 10:47 AM
If I was to get a converter at some point, what kind of tires would I need?
BigKap94z Jan 12, 2006 11:32 AM
He will custom tailor your converter to your needs man. Stall speed and STR will vary for what you want, and what your setup needs. I would guess something along the lines of a 2800-3200, especially if you plan on doing a cam or heads/cam in the future. You can tell him if you don't wanna run DR's or full slicks. Talk to John, he'll answer all your questions and get ya setup perfect. With a good set of DR's and a converter you should be in the 12's no problem, especially since your so close already.
Camaro 0wner Jan 12, 2006 11:48 AM
I wouldn't go any higher than a 3000. I think that would be plenty, since LT1's have a good amount of torque down low.
So, there really isn't any small mods I can do that would make me a bit faster. (MPH wise, which should make my E/T slightly better)
BigKap94z Jan 12, 2006 11:57 AM
Well there might be, I just know that would make a huge difference for you. You can do an electric water pump as well. 1.6 or 1.7 RR's/springs. It is relatively inexpensive considering the gains it would give.
LT1's do have a good torque powerband especially down low, however most people that I have seen that went with a 2800-3000 wish they went a tad higher. Think about it is all I am saying. I know its probably more than you really wanna invest right now, but the track gains it will provide will add up to more than a bunch of those little cheap mods you can do added up. I highly doubt you'll regret getting a converter, except for the cash you lose this week. lol. Your car will be a whole new animal with a properly setup converter.
ls1mongrel Jan 12, 2006 12:01 PM
Converter and some drag radials and you sgould be there !
Camaro 0wner Jan 12, 2006 01:01 PM
I'm convinced. I'll hold off on all those little mods. The most important thing is good tires and a good 60'. Nothing else I do (except heads, cam, which equals a lot of money) will really do a whole lot. Thanks for the advice.
Dragframe Jan 12, 2006 01:07 PM
2700!! Boise, ID.
Quit your bitchin... we are 5000+ here...
Speed Density Jan 12, 2006 01:35 PM
Congrats.......move.
nnolan Jan 12, 2006 04:05 PM
No one mentioned gears..... that would definately do it. If you have an a4 then you probably have 2.73s, switching to 3.73s would increase your acceleration by 37%. Good set of gears and a professional install would be about the same if not cheaper for a convertor and install. Plus you could wait and get your stall after you had picked or even installed your cam. Your cam will determine what size stall you want and I would suggest at least knowing the specs of your cam before buying a stall.
BigKap94z Jan 12, 2006 05:03 PM
I believe he has 3.23's if I remember correctly. Gears would still make a difference but not near as much as a nice converter. Also specs of the cam won't matter all that much in his situation....his car is a driver, and if he puts a cam in I highly doubt that he will put some monster in. A properly setup 2800-3200 would be plenty even with a cam like that.
© 2026 MH Sub I, LLC dba Internet Brands
