LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   355" LT1 goes 9's! (https://ls1tech.com/forums/lt1-lt4-modifications/437300-355-lt1-goes-9s.html)
T/ALT1 Jan 15, 2006 03:49 PM
355" LT1 goes 9's!
Well first off I want to say thanks to Lloyd Elliott for doing an awesome job on porting my new Trickflow heads. This is the same old combo that has been in my car for 2yrs. It has an old CC306, 4k Vigilante converter, stock torquearm, swaybar and shocks out back with 3.55 gears and on 26x11.5" ET streets. I made a couple motor passes and the tune was way rich and the car only ran 11.30@119mph. I turned the n2o (150HP) on and it ran.
60' 1.50 spinning.
1/8th 6.38
1/4 9.83@136mph!
I didn't get to make anymore passes since the car doesn't have a rollbar or any other safety equipment . Now I need to get the car on the dyno to do some tuning to get the car in the 10's on motor. Later
BizZzatch350 Jan 15, 2006 03:51 PM
Awesome Clint, the car is running great, its just nice to see some people still know what a well set up car can be capable of.
Pro Stock John Jan 15, 2006 03:57 PM
Sweet, sounds like a great combo. What was your 1/8th MPH?
T/ALT1 Jan 15, 2006 04:07 PM
They didn't show any 1/8th mile mph at the track yesterday but it normally ran 106mph when it ran 10.17@134mph so I would say a little better than that John.
NemeSS Jan 15, 2006 04:18 PM
so youre runnin the stock stamped steel tork arm,swaybar and shocks?
are they reinforced with metal?
i welded some tubular steel in the u channels on mine tork arm and panhard bar worked pretty good
what rear are you running?
congrats on the time! :hail:
kwikest i ran on my 383 lt1 was 10.22 @133 with spray back in '02-03
METALBEAST Jan 15, 2006 04:21 PM
Congrats nice time!
Evil Eric Jan 15, 2006 04:25 PM
Originally Posted by T/ALT1
60' 1.50 spinning.
1/8th 6.38
1/4 9.83@136mph
That is insane. Congradulations man. I hope my new setup is somewhere in the realm of that :)
I was wondering who else ahd done that :D
T/ALT1 Jan 15, 2006 04:33 PM
Thanks guys. Yes the rear suspension has stock stamped steel Torquearm, panhard rod and shocks. Later Clint
whynot Jan 16, 2006 12:35 AM
again, what rear is in the car?, and congrats.
BizZzatch350 Jan 16, 2006 02:09 AM
Think its a Ford 8.8
aintno6 Jan 16, 2006 03:07 AM
That's awesome man. I can't wait till i get these trickflows ported and build my 355.
Mike
Frank95z Jan 16, 2006 06:24 AM
Clint great job. I know you've been working hard on the car. Which track were you at? What was your short time on motor? Frank95z
T/ALT1 Jan 16, 2006 10:46 AM
Thanks, Frank the car ran 1.54 60' on motor 7.25 in the 1/8th. I found out the tune in the car was tuned for 30#'s and I put some 36#'s in it and it wouldn't run for crap on motor. I heated the bottle up quite a bit and put a little smaller fuel jet on the n2o. It worked b/c the car ran awesome. I am going to get it right and run on motor before I spray it again. I am also installing a 5 point bar but the car still won't be legal to run 9's but I am keeping it streetable so I am not going full rollcage. Later Clint
RealQuick Jan 16, 2006 10:52 AM
Nice!!!!!!!!!!!!
I cant wait to see how my 383ci LT1 with T76 turbo and LE AFR210's will run...once its back together :eyes:
Jon
Fire67 Jan 16, 2006 11:01 AM
Very nice setup!!! If your running an 8.8 rear, id like to know how it was setup and by who...
Frank95z Jan 16, 2006 12:45 PM
Clint that was at Eunice? I was just wondering if they were open. Frank95z
T/ALT1 Jan 16, 2006 06:30 PM
Yep in Eunice Frank.
Rare96WS6 Jan 16, 2006 07:57 PM
Wow! That is an insane run on motor and with just a 150 shot!
T-REZ Jan 16, 2006 08:09 PM
we need to see some video,great time. congrats
Evaporate Jan 17, 2006 01:00 AM
Clint, really nice times!!
I'm actually going with the TF's ported by Lloyd and an LE2 cam and can't wait to see how it will perform but will take a while to get it all put together.
Do the Trickflows not allow us to run OVC wiring? I could've sworn I seen that posted by someone recently?
Are the 30# injectors adequate for what you have?
© 2026 MH Sub I, LLC dba Internet Brands
