slp ram air i need to know were the bracket goes that came with the slp airbox for a 1994-97 ss hood thanks |
It should be the mass air flow bracket, when you get this thing done let me know how you got the airbox to clear the drivers A.I.R. tube on the exhaust manifold. |
it attaches to the head (i think) right around the coil. i took mine off 3-4 years ago cause it got in the way. |
ok thanks now where do i cut on the hood right above or on the side like the newer ss's |
it all turned out grate it took me a while to figure where the bracket went but then i found it to clear the air valve lossen it and turn it around diconect the hose and use the one that came with the air box. by the way i used a holley power shot air filter wich kandn dosnt make but if it did holleys are btter they flow more and diffently a big increase it power over a kand cold air intake plus sounds a lot better. |
© 2024 MH Sub I, LLC dba Internet Brands
