I cant figure out what's causing this Ok guys the car is a '97 6 spd. LT1 T/A. when i first start the car it runs fine for a couple of minutes then slowly starts misfiring badly, then A.I.R. pump turns on briefly(like 2 seconds) the idle will immediatly smooth out then slowly start doing the exact same thing over again. It probably does this every 2 mins. I replaced my EGR valve because of a EGR code. Still does the exact same thing, does not matter if its hot or cold. The car runs excellent other than at idle. Anyone ever experience a similar problem? I just did plugs, wires, and put in a brand new GMPP Optispark about 6k miles ago. Please help. Thanks. __________________ |
do the spacing mod for the ignition module, and what is the condition of your coil? |
spacing MOD for ignition module?..explain? =) |
How was the port for the EGR when you replaced it? Did you look to see if it was clogged up with carbon? Are you still getting an EGR code? |
Originally Posted by TransAm6383 spacing MOD for ignition module?..explain? =) |
ohhhh..it doesnt have to touch the head? |
No it does not. |
sweet..im going outside right now. |
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling slow96z already explained it, but theres the detailed version from shoebox. |
Possible o2 sensor? Not sure if that effects these as much as it did my driver. |
| All times are GMT -5. The time now is 07:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
