ABS not working at all
Old Mar 10, 2006 | 10:47 AM
maganeztransam's Avatar
Default ABS not working at all
My ABS is not working since I bought the car used.It is fun to drive because you can do cool tricks (read stupid stunts) but I almost crash into an Infinity the last time I tried one so I guess I need the ABS more than the adrenaline. I used to have the ABS light on, but not anymore. Any Ideas?
Old Mar 10, 2006 | 04:06 PM
the_merv's Avatar
Veteran: Air Force
My ABS system has been disconnected in the front, but the rear is still connected. Check the connections. The fronts are along the Lower control arm, and the rear is in the top of the differential. Check to make sure they are connected. Also check the ABS motor under the hood. It is located on the drivers side, under the Intake. It is the one with all the Brake Lines in it. There should be 3 plugs in that one.
