cats what is a good high flow cat going to run pacesetter longtubes to a pacesetter y pipe and i need a cat |
Here's my 96 SS with a Pypes 3" cat crossing over from the driver's side and a Catco 3" cat on the passenger side. You'll need a compact cat for the driver's side crossover and the Pypes or SLP is about the smallest. http://home.comcast.net/~jeffhansbur...-pipe1.jpg.JPG |
do i have to run the two cat setup or can i just run one after the y pipe |
you will get better flow with 2. Thats why the 97-97 made more HP then previous models. And you make even more with 0:D |
Originally Posted by chameleongreen97ta do i have to run the two cat setup or can i just run one after the y pipe http://i29.photobucket.com/albums/c2...Formula053.jpg |
To be somewhat legal you need 2 cats on a 96-97. Although technically, you're not supposed to change the location of either cat and longtubes definitely move the driver's side cat. |
© 2024 MH Sub I, LLC dba Internet Brands
