LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Can't read codes any ideas? (https://ls1tech.com/forums/lt1-lt4-modifications/546954-cant-read-codes-any-ideas.html)
z28fan Jul 24, 2006 08:39 AM
car is 97 trans am
The plug that is under the dash that you use the scan tool on. It does not seem to be sending any signal. Any ideas?
Someone installed aftermarket radio and some stupid under dash lights if that makes a difference.
brynnda Jul 24, 2006 08:50 AM
is the check engine light on?
02blutb Jul 24, 2006 09:06 AM
it may be that you are using the wrong code reader. there are 2 types (dont remember the names) but one works on the older LT1's and another works on the new LT1's
brynnda Jul 24, 2006 09:21 AM
obd1 obd2
z28fan Jul 24, 2006 09:36 AM
OBD 2 in a 1997 trans am.
yes the check engine light is on.
tha thing is I ran it through a scan tool myself and came up with no readings, So I took it to a friend who runs a mechanic repair shop, he had his scan tool - punched in the information (97, trans am, manual trans, etc) and his didn't come up with a reading either. What he thought was that it wasn't sending a signal out the plug.
mikes98z Jul 24, 2006 09:44 AM
z28fan..check the fuse that says "cig lighter"...the port where the handheld scan tool runs off the same fuse....my 97 T/A had a blown fuse and the scan tool would not read it.
Good luck
z28fan Jul 24, 2006 09:48 AM
Good idea- I don't think the lighters work either.
Be right back going into garage to check it.
z28fan Jul 24, 2006 09:53 AM
Ok the fuse looks like it was blown, Now I have to see if I can get ahold of my parents to borrow the scanning tool.
Thanks for the info -
You know this forum is really great, lots of information and very helpful people providing it.
mikes98z Jul 24, 2006 09:57 AM
good luck, the board helped me find out about the fuse too..good to pass the info along.
Domestic Demon Jul 24, 2006 10:22 AM
Thats the exact same problem my Cavalier had. I went to read the codes, and there was nothing. Turns out the Cigarette lighter and OBD port use the sae fuse, so I replaced it and problem solved :)
z28fan Jul 24, 2006 10:35 AM
It works.
Except now it reads
PO441
Evap Emissons Control - Purge flow fault
What does this mean, is it serious? What do I have to do to fix it?
© 2026 MH Sub I, LLC dba Internet Brands
