LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   LE2 Dyno. What's Wrong?? (https://ls1tech.com/forums/lt1-lt4-modifications/547303-le2-dyno-whats-wrong.html)
yotaman96 Jul 24, 2006 07:21 PM
Here is the first dyno run without any tuning except turning the injectors down.
http://i28.photobucket.com/albums/c2...mEmberton1.jpg
Here is the best dyno of the day.
http://i28.photobucket.com/albums/c2...mEmberton2.jpg
And here is the last dyno of the day. I'm not sure what the spike is.
http://i28.photobucket.com/albums/c2...ynolastrun.jpg
I also remember him saying that adding fuel was actually causing me to lose power. That's probably why the AF ratio is where it is. Okay, post your opinions. What's wrong with my car? I should have well over 400rwhp with my mods.
streetwarrior96 Jul 24, 2006 07:51 PM
I had a spike like that around 4700 RPM and turned out to be my LT4 Knock Module. They turned it off worked like a charm. Your A/F seems to be off also.
http://i31.photobucket.com/albums/c3...r96/rdyno1.gif
Jditlfm Jul 24, 2006 08:30 PM
I would still get that air/fuel ratio down, 14 to 1 under wot is not optmial, more like 12.5 to 1 or less if i remember corectly
1SLO6 Jul 24, 2006 08:33 PM
if your car is not tuned thats where your problems lies...
yotaman96 Jul 24, 2006 10:29 PM
This was a dyno tune.
SmokedOutZ28 Jul 25, 2006 04:31 AM
Did you install the cam the way lloyd wanted it installed?
yotaman96 Jul 25, 2006 08:07 PM
It came out to be 2 degrees advanced. He said that would be fine. Maybe my engine is just weak. :(
HBHRacing Jul 25, 2006 08:18 PM
your AF ratio is way off. They should have had it at low 13's to high 12's by the time you were done with the dyno tune. Assuming everything else is nominal, the tune changes should net you a little more power.
yotaman96 Jul 25, 2006 08:20 PM
Taking the ratio #'s down is adding fuel right? The tuner made the comment that usually these cars like to be around 13, but everytime he tried adding fuel it lost power.
TwoFast4Lv Jul 25, 2006 08:21 PM
DAMN! Did you pay for that tune? On that Dyno? Might want to find a better shop?
HBHRacing Jul 25, 2006 08:23 PM
yes, lower number = richer. If they cant tune you for optimal power in the correct ratio, either they have a problem with the tune, or there is an underlying condition. It wouldn't be uncommon for each motor to be a little off and like a little more, or a little less fuel, but 14.1:1 is way in the wrong direction.
yotaman96 Jul 25, 2006 08:23 PM
$250 for 13 pulls and tuning sounded fair to me. I know the guy from a few friends. He has had many LT1 cars and now has a turbo LS1 car. He has always seemed to know what he's doing.
yotaman96 Jul 25, 2006 08:25 PM
I have thought about trying another shops dyno tune. I haven't been driving it, because I noticed a knocking noise. I hope it's not a rod. I haven't had time to check into it yet.
HBHRacing Jul 25, 2006 09:06 PM
thats might be your "underlying problem".
Either way, 14.1 is no good for PE mode. Not just for performance, but for safety. It's just far too lean. Thats why stock you hit in the 11's, it's safer.
scrmnws6 Jul 26, 2006 12:47 PM
I made 400 rwhp and 365 rwtq. I forgot to degree the cam though, my fault. I was expecting something in the 410-415 rwhp range, but I guess not.
The knocking might be coming fom your RR's. My friends were louder than a diesel. He called the company and they sent him out new ones.
yotaman96 Jul 26, 2006 09:41 PM
Well, I haven't done a compression check yet, but I'm pretty sure I have a major shortblock problem. We started the car tonight and let it run for a few minutes. Then we took the temp of the header primaries and cylinder #8 was showing about 150-200 degrees cooler than the rest. This find along with the knocking pretty much assures me there is a big problem. If that cylinder isn't firing properly, I guess that would explain the dyno being so low. I don't know a lot about the way things work, but I also was thinking that could be why I was losing power when the tuner was adding fuel. It wasn't buring properly. It wasn't knocking when we dynoed the car, but maybe pushing it to 6500rpm a few times finally made the problem noticeable.
I would like to thank Lloyd for trying to help me and he has been great the whole time dealing with him.
HBHRacing Jul 26, 2006 09:49 PM
Don't jump to motor rebuild just yet. I would really advise that you yank the valve cover off that side and look at the valve train. Maybe you dumped a rocker or have a valve issue on that cyl. That would also explain the noise, and the cold temps due to non combustion.
Maybe it's simple, maybe not. But I would really start there first, considering thats the area you were just in while doing the install.
© 2026 MH Sub I, LLC dba Internet Brands
