What's next for your LT1? Intrested in knowing what your current setup is and what you have in store. I have yet to see the full potential of my setup so I'm going to say tuning and taking advantage of what I have before going futher. What's your plans and what are your goals? My goal is low 11's N/A and low 10's with the spray. Let's hear it :) |
right now:few basic boltons, exhuast, rr's, little bit of ignition stuff, on the way: electric waterpump, double roller timing chain for a SBC(dont need the cam drive for the pump so i can use it in the LT1 block and get more power in that chain for 39$ than i could for a few hundred for a high performance lt1 timing chain) planned: LE3 package set for low compression, STS kit with the biggest turbo i can get on it and still be efficient, forged interals for a 396 kit, splayed to a 4 bolt, fuel delivery setup to back it up, S60 with 3.73s in it likely, and a built T-56, and go crazy on the suspension, thats the plan now unless something better comes along, but it will be awhile cause im still a poor college student, but im doing a mech. engineering degree so the potential for the income to fund my toys is there as soon as i graduate |
Wolfe 8pt Roll Bar. :devil: Tony. |
I forgot to mention, I want to go single plane but until I get a Dana44 I'm screwed. |
cc306, elec h20 pump, double roller, comp 918's, chromoloy push rods, vented opti swap, 3.73's, auburn posi, and 17x11 zr1's...all on a 355ci lt1 with a TCI rebuilt tranny, 2800 stall (bigger later), dynomax headers, and no headliner haha. i wish all of these parts were actually in the car and not sitting next to me! |
finish up replacing little stuff here and there from the wreck,redo my exhaust again because it sounds like a damn truck with glasspacks,i dont like it at all, after that probably headers and gears |
1995 Camaro Z28 x MODS ENGINE: SSEFI LT1 Splayed 4 Bolt Eagle 3D 6in Rods Eagle 4340 Non-Twist Crank Shaft J&E Flat Top Pistons(12.0:1) CSI Water pump SLP Cold Air Intake 1LE bellows LPE 58mm Throttle Body Ported LT1 heads 2.055 Int 1.57 Ext SSEFI Custom 240/247 CamShaft Double Roller Timing Chain Crower Chrome Moly Push Rods Hooker Long Tube headers TwoFast4LV Custom Y-Pipe Dynomax 4 inch In/Out Muffler behind Y-pipe DHM Electric Cutout SLP Duel Duel Cat Back x x DRIVE TRAIN: Yank Thruster Pro 3800 stall NW Differential Built 3.73, 33 spline 12-bolt Eaton 33 spline HD 1000Lbs bias T/A Rear end Girdle RaceTronix Fuel kit Kit MSD 6T ignition SLP Fan Switch Speed Secrets Calibrated/Tuned, stock 4L60E Speed Secrets tuned motor with LT1 Edit SUSPENSION: '98+ brakes Bogart/Mickey Thompson ET Street Wheels for drag strip Polyurethane bushings 26mm rear bar BMR TQ Arm Adjustable LCA locators. Lakewood LCAs Lakewood Pan Hard TwoFast4Lv SFCs HAL 12-way adjustable shocks HAL drag springs EXTERIOR: SLP SS spoiler 2001 SS 17" rims PIAA Low beams and Hyperwhite High beams PIAA Fog lights Six light conversion (four head lights and two fog lights all at once) Clear corner lenses Rebadged with Bowties Zaino! INTERIOR: Color matched Gauge panel Graphite Cloth Bose Five speaker CD Thanks to John Kelchen! FIRE BAD!!! SAFETY/MISC: Morrison 8 point Roll Bar G-Force Five point harness Custom Built DS safety loop C-Clip eliminators RCI Tansmission Blanket Ford Starter Soleniod SFI Flex plate SFI Harmonic Damper DYNO: 412 RWHP / 422 lb/ft torque (S.A.E. corrected) BEST 1/4 TIME: 11.47 @ 118 mph with a 1.59 60' (NA) N2O times Coming .................................................. .................. Next we are actually going to tune it and finish installing the N2O System. In the next few years it will probably go 18* with a Hogans and get a full cage |
I plan on doing a LS1 or 408 iron block swap in the next few months. :drive: Then a tranny rebuild and a 12 bolt. Its gonna be a fun project im hoping for high 10's with a good heads and cam set up. |
Originally Posted by 95-CAMARO-V8 I plan on doing a LS1 or 408 iron block swap in the next few months. :drive: Then a tranny rebuild and a 12 bolt. Its gonna be a fun project im hoping for high 10's with a good heads and cam set up. |
Trans brake, and Ford 9"...... Want to get those 60' times down and run in the 10's on a small shoot of Nitrous.... |
get my cam finally put it, and a new tune and dyno fix the tear in my pass. seat.. paint- pewter metallic with gold flake and my NBM decals sprayed on. wheels - the wheels on chases old electron blue ws6 with ghost flames, if i only knew what they were called.... zinc plated drilled and slotted rotors, i beleive you cant have nice wheels w/o nice rotors. bilstein suspension.. in that order sometime during all that - embriodered headrests with custom floor mats |
got some strong LT1's out there good job guys :hail: Need a to get a bigger cam for mine |
Go a lot faster and make it look a lot better :) |
hey neil you get your 306 yet heard about it getting screwed up in shipping over in the TX section |
well, to start with, my near future plan is to start the car and drive it, haha. on serious note, I'm getting 3.73's with the whole shebang tomorrow after work, My Custom light weight SS Hood and rear spoiler should be ready by Monday. after that, I will order an EWP, a 6AL box, front and back BMR sway bars, BMR STB, and ill get my rear springs replaced (still on OEM ones). the first rebuild is done, but I am already thinking of the next on, i want to get a real cam, Heads, a short Block 396 that my friend have been trying to sell for the past 6 months, single plane intake, and Nice Dose of Juice. |
Current Mods: MSD 6A, coil, cap and rotor SLP short throw with custom stick and B&M t-handle K&N cold air intake, Granatelli MAF/cold air tuning, Trickflow ceramic elbow, air foil Jet stage2 chip BBK ceramic shory headers/ypipe, 3 inch flowmaster catback, test pipe Spohn LCAs, adj. panhard, adj. torque arm Bilstein shocks Energy suspension hyperflex kit 17x9.5 z06 wheels, 275/40 sumitomo HTR+ LS1 driveshaft LS1 front brakes, pbr carbon cermamic pads, Baer decelarotors, ebc green stuff pads and some made in china rotors on the rear(slightly larger than the stock rotors). Autometer sport comp tach/blue lens/blue led 1.6 Promagnum roller rockers/comp cams valve springs Be Cool 170 thermostat Currently awaiting install: Richmond 4.10 gears SLP subframe connectors Sportcomp a/f, nitrous pressure, fuel pressure gauges zex dry kit Racetronix fuel pumpkit/walbro 255lph Summitracing manual exhaust cutout MSD 3 stage retard/window switch My end all goal is for tubular k member, a arms, procharged 383 with a transzilla t56 and either a 12 bolt or 9 inch. |
Phase 1: Finish My Bolt Ons first. I just ordered the Electric WP. Then fix all the small things that where wrong with the car when I bought it. Having both rear 1/4 panels, rear bumper, front fascia,1 front fender and both doors repainted, then Im replacing the hood with an SS and the spoiler with an SS. Then comes wheels and tires, and suspension (auto-X). Phase 2: Low compression fully forged bottom end first,havent decided on cubes. Then hang a t-60 out back. Then afterwards Ill do a custom grind cam and raised runner AFR LT4 heads. |
Originally Posted by Texas_TA hey neil you get your 306 yet heard about it getting screwed up in shipping over in the TX section Yeah, they sent it to the wrong house. :bang: |
set-up in sig. upgrading my blower from a p1 to a d1 and throwing a full cage in. my best now is 11.03@123mph :) hope to be a low in the low 10 area until i tear up my 10 bolt,yes i 'm running low 11's with a 10 bolt :eek2: |
Sell my Delteq to buy a wet kit and get le2 heads :drive: |
| All times are GMT -5. The time now is 08:19 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
