Where can i buy SVO 30# injectors??
Where is a good place to buy SVO injectors? Under Jegs and Summit they wont show up under LT1, also they just call them Ford injectors?
hey guys thanks for your help I ended up finding these. Hopefully they work alright..
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
that's a good deal oN SVOs. they used to be cheap. I picked mine up for $214 new from summit (got them for $114 cause I had a $100 Gift Certificate). Now they're $275 for the standard 30lb SVOs
I have a brand new set of Holley injectors (Delphi), 30#, still in the factory blister pack:
These are going for $544 new at Summit. They came with my fuel injection kit but since I decided to go with a blower I upgraded to 50# injectors right away - never even opened the 30's.
I'll sell them for $245 plus shipping from 95051.
Here's a picture from Summit and their description:
Brand: Holley
Product Line: Holley Fuel Injectors
Injector Advertised Flow Rate (lbs/hr): 30 lbs./hr.
Injector Advertised Flow Rate (cc/min): 315.0cc/min
Quantity: Sold as a set of 8.
Wiring Harness Included: No
O-Rings Included: Yes
Notes: 480 HP maximum at 43.5psi fuel pressure
Fuel Injectors, 30 lbs./hr., High Impedance, 12 V Saturated Circuit Driver, Universal, Set of 8
PM me if interested.
Jim
Brand: Holley
Jim
Honestly I think it because they figure if you can put together a combo thirsty enough to need injectors that size you have spent a lot and they want their cut.
I am running 32lbs on the AI combo and they are about 85-7%DC with good a good air fuel ratio, belton 1/4 mile MPH and injector duty cycles point at a little better than 400rwhp and 480fwhp.
Also consider the SVOs are rated at 39psi our stock pressure is 43.5 so they will act as 31.7
