what's the best puller?
Old Feb 24, 2003 | 06:14 PM
1badblk94TA's Avatar
Default what's the best puller?
I just found a oil leak under my car at work today, i think its comming from the front main seal. need to know whats the best puller to use to get the balancer hub off. also dose the dip stick have an oring or just suppose to fit tight i think it might be leaking a little there also.
thanks
Old Feb 24, 2003 | 06:22 PM
96SCTA's Avatar
Default Re: what's the best puller?
my dip stick did not have an oring. Amd as far as the best puller i got a goood one from advace auto. One word of advice make sure the bolt that holds is on is as far into the treats as possible. When i did mine this winter i had it a few threads out to many and it bend the bolt and destroyed the first few threads in the crank..
good luck
