Which header?
Old 09-29-2006, 03:08 AM
Ironxcross's Avatar
Default Which header?
I went looking for some headers online I've found:
Dynatech coated and stainless steel
http://store.summitracing.com/partde...5&autoview=sku
and
Pacesetter coated, steel
and
Pacesetter uncoated, steel
are the dynatech ones a good deal? or am I just looking in the wrong place? Also I'm trying to stay emissions legal.
Old 09-29-2006, 03:25 AM
brynnda's Avatar
hooker super comps!!!!!!!
Old 09-29-2006, 03:52 AM
Ironxcross's Avatar
haha, nah, super comps bring back memories of almost constant rattles, reduced turning radius, and daily retightening. it wasn't on an f-body, but just out of spite I'm never buying another super comp, EVER.
Old 09-29-2006, 05:47 AM
brynnda's Avatar
well i have slp shorty headers, i dunno if i wouldnt put them on there, i bought her with them, but theyre ok i guess. guy i got her from was trying to clone into an lt4 firehawk
Old 09-29-2006, 02:58 PM
Ironxcross's Avatar
shorties? eh, we both need some LTs
Old 09-29-2006, 03:17 PM
Bowtie Boy's Avatar
how about these pacesetters
http://www.neweraperformanceparts.com/n/neweraperformance/default.asp?SID=xRTRARX3P2L757PQDSA3PF&S=503&A=E&P KV=pshlt1|0
cheapest price and free shipping, coat them and wrap them yourself
Old 09-29-2006, 03:28 PM
CL21376's Avatar
I went with Jet-Hots (essentially Super Comp's but with thicker flanges and a little better welds).
I dont think there is much difference between Pacesetters/Hooker Super Comps/and Jet Hots. I'd go with whatever is cheaper. At the time, I got in on a group buy on Jet Hots ($450, i think?). They all make emissions compatible headers, but they are going to relocate your cat pretty far back, which might fail a visual inspection.
Old 09-29-2006, 09:54 PM
MrCadillac's Avatar
Do not wrap a header on the street!! They collect mostiure and will rust them in short order. even if they are coated, the constant water on them will eat it in no time!!
coating them yourself can be a very effective option. so long as you prep it right, and get an even coat, in multi layers.
Old 09-29-2006, 10:33 PM
Ironxcross's Avatar
i dont know how to coat it though, so that might be a problem. how hard are they to put in? and do I HAVE to use poly engine mounts to prevent the Y-pipe from slapping the floorboard of the car?
Old 09-29-2006, 10:34 PM
buffman's Avatar
coating a set of headers yourself will never compare to a professional shop who has the proper equipment to do it.
As for the header wrap, the **** is garbage. Even a lot of circle guys have gone to ceramic coating cause they're tired of replacing their headers ever year
Old 09-29-2006, 11:31 PM
Ironxcross's Avatar
can you be emissions legal with LT headers? or does it vary state to state?What else do you need when installing the headers other than the headers themselves, the time required to install them? I read something about poly motor mounts and a tune so the rear o2 wouldn't bring up the SES light. Do you need to buy a Y-pipe?
Old 09-30-2006, 02:06 AM
MrCadillac's Avatar
the rear O2 deal is only if you delete the cats. I don't think NJ will allow the use of LT's, since you move the cats. I'd look into your emissions laws. you can alwasy keep the stock manifolds and pipes, and swap them on for the emissions part. Some may say that is shady, but what is shady is not letting us run long tube headers on a street car!! I'm glad I don't have emissions testing!
Buffman is right, it won't be the same as getting them coated by a pro, but if money is really that tight, and you don't mind redoing it every year or so, go for it. me, I have mine procoated... now I just need a car to put them on!
Old 09-30-2006, 02:23 AM
JUICED96Z
Guest
Posts: n/a
KOOKS ALL THE WAY!!!!!!!!!!!! that is if you can afford it lol.
Old 09-30-2006, 03:27 AM
Ironxcross's Avatar
so that means mids for me... or i could just do it anyway.. how much hp would i be skipping out on if i went to mids?
Old 09-30-2006, 02:11 PM
Ironxcross's Avatar
ttttt
Old 09-30-2006, 02:12 PM
streetwarrior96's Avatar
No problems with my Hooker supercomps.
Old 09-30-2006, 07:23 PM
95formulalt1's Avatar
def get it coated
Old 09-30-2006, 09:20 PM
the_merv's Avatar
Pace Setter Coated LT's, and no major problems with them. I am lowered, and they are decent in the ground clearance, a couple of scrapes every now and then.
Old 09-30-2006, 09:44 PM
Ironxcross's Avatar
what did you guys need to do to get them installed? new Y-pipe or anything?
Old 09-30-2006, 09:45 PM
always faster's Avatar
Excatly
DO IT ONCE, DO IT RIGHT
Quick Reply: Which header?
