LT1 AFR's??? i got a buddy looking for a set,but he said he cant find any.what shops sell's them? |
It rare that you find a place that has them in stock, As far as I know they are made on order. |
Originally Posted by streetwarrior96 It rare that you find a place that has them in stock, As far as I know they are made on order. |
Tell your buddy to do some research and find out that AFRs are not what he wants and that he should be looking to port the stockers. |
Originally Posted by 96capricemgr Tell your buddy to do some research and find out that AFRs are not what he wants and that he should be looking to port the stockers. |
Originally Posted by weaponZ please explain why stock ported would be better than AFR's. |
u can get just as good or better for less |
Originally Posted by streetwarrior96 u can get just as good or better for less |
I he really insists on making the AFR mistake I have a friend considering getting rid of his TPIS ported ones in favor of some AI 190s like I have. The AFR stuff was good on gen 1s GM stepped it up in a big way with the LT1 heads and all AFR did was make the same old castings reverse flow in doing so they are basivcally giving you OLD gen 1 designs. ALL the fast LT1s you see with AFRs spent cubic dollars on making those turds work back before shops had maximized the stock heads they way they have and today folks are going just as fast with a lot less in the whole car not just in the heads. |
i went with thwe trick flows on my 383 they flow great but i did have them ported and polished before they went on but stock heads with porting and polishing with a 3 angle valve job work great for stock bottom ends |
I wonder how well the new AFR heads will do in 5 weeks. |
what if your procharging a forged 355, dont go with AFRs, what heads to use. |
he has a built 385 forged bottom end with a hefty custom grind cam and he's set on AFR's.what new heads are comming out in 5 weeks? |
I'm not sure why everyone is knocking on the AFR heads, i couldn't be happier with mine. |
Originally Posted by SLPHawk300 I'm not sure why everyone is knocking on the AFR heads, i couldn't be happier with mine. |
I dont think anyone is knocking them. I think that what is being said is there are better options for your money depending on what your goals are. Seems true concidering there are plenty of Stock ported head guys seeing over 400. |
Originally Posted by Honda Hunter I dont think anyone is knocking them. I think that what is being said is there are better options for your money depending on what your goals are. Seems true concidering there are plenty of Stock ported head guys seeing over 400. |
Iron LT1 heads are 64cc chambers as are Trickflows. You would think people who own parts are a good source of info on the results of them but in my observation with expensive things like OH say AFR heads those who make the mistake will defend it to the grave never admitting it was a mistake. Not all guys who make expensive mistakes like that do so but many do, it takes a big man to say they were wrong. |
Originally Posted by 96capricemgr Iron LT1 heads are 64cc chambers as are Trickflows. You would think people who own parts are a good source of info on the results of them but in my observation with expensive things like OH say AFR heads those who make the mistake will defend it to the grave never admitting it was a mistake. Not all guys who make expensive mistakes like that do so but many do, it takes a big man to say they were wrong. |
| All times are GMT -5. The time now is 10:06 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
