lean= Runing Hot? and some other Q's
My car runs a bit hotter than it should be, I've Hooked it up to a wide band the other day and it was runing lean really bad any where over 2000 rpm, does that hae naything with it runing hotter?
as for ruining lean, I have doubts about my Fuel pump and injectors, the pump will defiantly be replaced by a race tronics pump, so i was wondering, do I change my injectors to 30lb SVO's or just clean the current ones; and i will be ruining a 100+ shot of juice later on this year (wet)
fuel pump and injectors are the ones that the car came with from factory in 1994.
