I got the SHAKES!! My LT1 has a stuttering problem that can't be diagnosed because the engine light does not show. It started a few months ago to what seemed to be a misfire with the pistons that lead to a loss of horse power. Heres a list of things that I've gotten done to this day: -spark plugs/wires -optispark (twice) -replaced water pump -flashed computer -injector flush I've been told that the injectors had a bad ground and were cutting in and out. Before installing new plugs two days ago, the stuttering came and went on idle, in reverse, high speeds, low speeds, park, etc. Even in all temps. Now after changing the plugs it has become consistant throughout the drive. I've checked a double checked the .50 gapping on the plugs and double checked the wire ends. All Kosher. Please tell me I'm not the only one. HELP! sick of all- eddie |
Does this only happen at idle? While running? Durring all rpms? |
LMAO at "While running" "Nope... goes away when I shut it off.... HHHEEEEEEEEERRRRRRRRRRREEESSS your sign!" :D Replace the fuel filter. You can send the $80 to my pay-pal lol (Even though it only took me a second, I have to charge you for one hour of labor) |
Lol, that was good.. |
Originally Posted by evalless My LT1 has a stuttering problem that can't be diagnosed because the engine light does not show. It started a few months ago to what seemed to be a misfire with the pistons that lead to a loss of horse power. Heres a list of things that I've gotten done to this day: -spark plugs/wires -optispark (twice) -replaced water pump -flashed computer -injector flush I've been told that the injectors had a bad ground and were cutting in and out. Before installing new plugs two days ago, the stuttering came and went on idle, in reverse, high speeds, low speeds, park, etc. Even in all temps. Now after changing the plugs it has become consistant throughout the drive. I've checked a double checked the .50 gapping on the plugs and double checked the wire ends. All Kosher. Please tell me I'm not the only one. HELP! sick of all- eddie |
any word? |
Yea, could be Fuel Filter, or Fuel Pump. Mine didn't even run when the Fuel Pump went. I was pissed, rolled up to a friends, parked, then went to start it and it wouldn't even start.. |
Originally Posted by the_merv Yea, could be Fuel Filter, or Fuel Pump. Mine didn't even run when the Fuel Pump went. I was pissed, rolled up to a friends, parked, then went to start it and it wouldn't even start.. |
Wonder what mine will do when I get it back together and try for the first time. The Moment of Truth.. |
© 2024 MH Sub I, LLC dba Internet Brands
