LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   No 02's how will it run (https://ls1tech.com/forums/lt1-lt4-modifications/594218-no-02s-how-will-run.html)
Dzman Oct 18, 2006 01:10 PM
How will my 97 z28 run with no 02's?My car wont stay runing and pops a lil and when it dies smoke comes out of the intake is this bc there is no 02's?
jm93camaro Oct 18, 2006 01:38 PM
Sounds like an ignition problem and don't try to run it without the o2's, will run even crappier.
Dzman Oct 18, 2006 03:11 PM
The not wantin to run prob was the badgas from sitting I put some stuff in the tank that helped alot the more I run it the better it gets I think its had half hour run time in all with no 02's
infinitebird Oct 18, 2006 04:17 PM
You should be able to run fine with no O2s, that's how it runs anyway in the first few minutes after startup.
Your fuel efficiency will be bad though.
buffman Oct 18, 2006 05:09 PM
open loop will run fine with no 02s, but when closed loop comes around. Forgettaboutit.
FAD2BLK93 Oct 18, 2006 05:44 PM
If you unplug the 02s shouldn't the car stay in open loop, and run off the open loop tables.
rkinney Oct 18, 2006 05:58 PM
Yeah, I don't think it will go into closed loop. I had a buddy at work putting a lt1 in 56 chevy truck using a 93 ecm, and for some reason only using one bank's o2 sensor. He left one bank unplugged and pcm never went into closed loop. He ended up splicing the signal wires together and using one o2, and once again I don't know why he didn't just use both banks. Once he spliced them together then the ecm would go closed loop. If you do stay open loop it will run rich unless you have a way to tune the ecm. Then you can just tune the car to run open loop all the time, though I don't know if that would be best. My car runs great when tuned to run open loop all the time. Just some info.
97blkz Oct 18, 2006 06:40 PM
It will not idle and run like ass!
UnitZ28 Oct 18, 2006 07:03 PM
just leave them in... you will have no gain from taking them off
infinitebird Oct 18, 2006 08:22 PM
:loco: It will never go into closed loop if you do not have O2s.
infinitebird Oct 18, 2006 08:24 PM
:rolleyes:
If it does that I'd say you have another problem. I ran with no O2s for several months and had no issues. My old O2s went bad and I didn't get around to replacing them for a while so I just unplugged them.
It might run slightly rich since the pcm cannot make adjustments to the fuel for different pressure/temperatures and such, but it shouldn't cause any major problems that would prevent the engine from running.
Dzman Oct 18, 2006 10:32 PM
Well I do have one 02 hooked up I had to cut it and make the wires longer for my long tubes so not sure how good its runing.It did have gas sitting for over a year in it so not sure if thats why it pops a lil at idle or if I have to change a nother plug wire.After 5 good mins of idling the car will jus die and is a bitch 2 restart!!!
FAD2BLK93 Oct 19, 2006 02:31 PM
Change the fuel and check the fuel pressure. If you are only running one 02 then it sounds like you are running in open loop already. My car has a stumble off idle, so I unplugged 1 02 to richen the mixture, the car stays in open loop. the stumble is gone and it has never idled more smooth!
© 2026 MH Sub I, LLC dba Internet Brands
