MSD ignition
Old Oct 20, 2006 | 02:43 AM
pyronotic138's Avatar
Default MSD ignition
how hard is it to install a complete MSD ignition setup on a 1995 TA. please help me on this
Old Oct 20, 2006 | 03:09 AM
Dragframe's Avatar
easy... but why? unless your running nitrous and using it to retard the timing and as a rev limiter instead of hte stock one there is no point... all it does is make the Opti go out faster...
I did it... took longer to mount the box than it did to run all the wires and loom it to look factory.
Old Oct 20, 2006 | 06:02 AM
Formula350's Avatar
Yea, it's really easy with the right connector. I sadly don't have any knowledge about the Opti, so I"d take Drag's word for it. I have a 6+ Digital I don't know if it works, I should install it on my junker 90 Corolla to see LOL
Old Oct 20, 2006 | 11:16 PM
well i am going to run nitrous prolly just to boost up the compression a little bit. the motor only has a 9.5. and untill i can get a charger then i will run it. anyone have a wiring diagram for a 1995 lt1.
Old Oct 21, 2006 | 05:40 PM
camar0corey's Avatar
MSD wiring instructions/diagrams
Pick whichever box you are going to install.
Then chose the directions for a dual connector coil. Example
I think they make a premade harness also? Not quite sure.
