can you guys ad to the list for my nitrous set up?
getting ready to intall a wet nx kit on my bolt mods on 97 z/28 with m6. i was going to get a msd 6al box with wiring harness, window swich, and bottle heater. what else i'm i missing? thinking of a 100 shot or do you think i should stay with 75 shot?
75 is weak these car handle 100 all day long. and it timing has been advanced to NOT spray,till you get it pulled.also i changed to tr6 plugs and it made a huge difference, for the better
The Malory 685 box is better suited for nitrous use as it has built in window switch and timing retard. Also, you don't have to deal with pils top set it up.
It's also nice to have a fuel pressure safety switch.
Lets see if I can remember all the things offhand that I have
HSW wet kit
Walbro 255lph pump
Heater
Dynotune pressure gauge
Mallory 685 (ignition box, window switch, timing retard, 2 step, rev limiter ect.. all in one)
Switch panel
and I'm sure i'm probably missing some stuff. BTW I'm spraying a 150 on a heads/cam/stock bottom end car.
HSW wet kit
Walbro 255lph pump
Heater
Switch panel
