1st gen in 97 camaro.
Will my lt1 headers work on a 1st gen sbc?Is there any custom motor mounts so the cowl doesnt have to be cut?I already have a ramair hood.What can I do about the brakes the cam is big and wont power the brakes.Any help thanks!!
Originally Posted by GIZMO
I know that they will work with the Fast Burn heads, but I'm not so sure about the older style heads.
Did u use your stock lt1 fiuelsystem?I wanna know how to make my EFI system work on a carb setup.
Originally Posted by captaindbol
All you need is a low pressure bypass style regulator. Not sure if the stock return line can handle that much fuel though.
