LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Temp guage doesn't work (https://ls1tech.com/forums/lt1-lt4-modifications/599622-temp-guage-doesnt-work.html)
P_funk22 Oct 28, 2006 05:44 PM
As I was driving home, my temperature guage all of a sudden dropped to nothing and won't budge. I just had my plugs changed and I heard there is a coolant sensor of some kind between the 1 and 3 plugs. My motor is too hot right now to reach around and feel for things and I won't be able to think about anything else if I wait for it to cool. :bang: Anyone know about this sensor?
the_merv Oct 28, 2006 06:40 PM
Yea, you are right, that is the one for that guage. Make sure the wire(s) didn't burn up on the Header/Manifold. If not, then you will probably have to change that Sensor. What year is your Car, I ask cause mine has a very interesting Connection on the back of that Sensor, and you have to check it at the store.
hyperzone Oct 28, 2006 06:42 PM
yes, it is on the driverside head right between the first two exhaust ports. You cant miss it. Its really no big deal, your gauge will simply not operate but there should be no worries because there is another temp sensor in the water pump and that is the one that actually works with the computer. I'm looking for the part number right now for you and for myself since I know my own is fried and I need to replace it as well... good a time as any I guess to look it up.
Formula350 Oct 28, 2006 06:57 PM
My guage stopped working too, but it's my gauge :\ I tapped the instrument cluster a few times and it works now, bleh
hyperzone Oct 28, 2006 07:03 PM
Cylinder head temp sensor PN: 25037332
Water pump temp sensor PN: 15326386
Courtesy of our beloved LS1tech brethren before us: Cooling part numbers
- Gauge temp sensor has only one wire coming off of it, this is normal
- Water pump temp sensor has two wires
* dont mix up the two :)
P_funk22 Oct 28, 2006 07:15 PM
Dude! The guys that changed my plugs cut the wire off right at the connector. There is only a little stub of wire left, not even enought to splice it back together!! I felt down there and there wasn't a wire coming off it, it was wrapped around my steering linkage. WTF?!?! Will I have to find a plug at a junkyard with the wire still attached and splice it onto my wire or do they sell just the plug and wire as a unit? The sensor it good, just the plug is screwed. Also it's a 96.
the_merv Oct 28, 2006 07:21 PM
You can take the Plug apart, and re-wire it. That plug is a bitch to find. I had to make one for mine.
hyperzone Oct 28, 2006 07:21 PM
shitty! I dont know about finding just that plug. Since its toast regardless, why not see if your able to take it apart? maybe you could repin it and still use it. Otherwise, I liked your going to a junkyard and finding another plug idea alot better.. much easier to just splice the wire back together. Get some heat shrink tubing to put around the splice... dont use electric tape. E-tape will work I guess but, IMO the heat shrink is less ghetto.
P_funk22 Oct 28, 2006 07:23 PM
I have the plug off and taken apart, but I can't reach the little stub of wire that's left with my needle noses. Damn, this is annoying. Just to be clear, just the guage won't work, my PCM won't get confused or retard timing or not turn my fans on, right? It is the sensor in the head, not the water pump, that is messed up.
the_merv Oct 28, 2006 07:30 PM
Yea, you will know when the one on front of the Motor shits out. The car will run like crap. This is just the one for the gauge on the dash. I still like having all my gauges operable, but that's just me.
P_funk22 Oct 28, 2006 07:34 PM
me too, but until i can find a replacement, i want to be sure i'm not destroying my car by driving it. well, destroying it that way, I'm sure romping on it all the time is taking it's toll as well. :)
the_merv Oct 28, 2006 07:38 PM
Been there, that's why I had to drop $1800 in building my new Motor. Got a better setup though :)
Break it and build it better.
hyperzone Oct 28, 2006 07:38 PM
The car will run fine without the sensor your talking about. I personally would still fix it but, rest assured, it will not inhibit the car other than no visual indication of temp.... Actually the temp indicated by that gauge is usually off by as much as 40 degrees at times anyway, ha! Should really be called "cylinder head temp" since its not really getting the temp of the heated coolant due to the reverse flow... haha.. I'm just rambling now..
P_funk22 Oct 28, 2006 07:43 PM
My car got hit by some dumb whore a couple years ago so I used that as an excuse to add mods. I told my wife "the wreck messed up my exhaust manifolds, I have to get these headers to fix it" Same with the gears and cat back and such. I don't know how I'll explain the heads and cam ;) Thanks, guys, for your help, I'll keep working on this plug, but it looks like I'll be hittin the junk yards next weekend.
the_merv Oct 28, 2006 09:09 PM
That's good.. :jest:
Ask her what 710 fluid is..
© 2026 MH Sub I, LLC dba Internet Brands
