What is normal cylinder wear and what is not?
Got some scratches in nearly ever cylinder, some are more numerous than others. The scratches are around an inch or two in length and appear to be in the same uniform places on all cylinders.
Block has 78K on the clock and does not burn oil and ran cery strong before tear down, reason for tear down is worn camshaft bearings.
Attached below is a photo of the worst scratches, they can be felt with the tip of the finger. I would guess that the scratches are around .002" - .004" tops.
I really dont know much about honing, what is it capable of fixing? The cylinders are by and large good and does not shown any wear at the tops nor anything else but these scratches. Can honing fix this?
i would take it to a mechine shop and get it blueprinted. Thats the best way to do it unless you have mic's and t gauges and know how to use them. they will tell you how bad the wear is and what kind of machining is needed.
If you don't want to worry about things later clean it up good now while it's out, it may save you money later.
If there aren't deep scratches (have a machine shop give you a recommendation) honing and re-ringing with fresh bearings will get you another 70K easily thought just to contradict my top statement.
If you dont hone it I'll drive over and slap you Honing is a peice of cake. Go get a dingleberry hone (tall looking one with a bunch of round stones on wires), I think they're $25-30. Don't get the flat stone one. Just get an electric drill (corded, not battery) and go up and down the cylinders a few times untill you can see nice hatch marks. I'm sure there's a tutorial somewhere on the net to help you. If you have the money, you might as well bore it .030 or .040. Get some forged pistons.
Originally Posted by freshlt1z28
it looks like you are going to need to seriously ridge ream them. That ridge at the top of the cylinders looks fairly thick. But that doesnt make a difference if you are going to bore it.
Originally Posted by wrd1972
That is carbon ridge on the cylider tops, already check with a razor blade to make sure. What would you guys do with those scratches on the walls?
1. use as-is
2. Hone and ring
3. Bore to 355
Right now money has turned tight.
1. use as-is
2. Hone and ring
3. Bore to 355
