LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   I'm stumped. Please help! (https://ls1tech.com/forums/lt1-lt4-modifications/604795-im-stumped-please-help.html)
thecamarokid Nov 7, 2006 11:23 AM
I drive a 93 M6 Z28. A couple weeks ago I noticed a little misfire but didn't think to much of it. As the days went be the miss got worse and worse. I finally pinned down exactly when it does it. Anywhere between 2,000-3,000rpm at anything but full throttle. If it starts missing I just floor it and it goes away even at a low rpm. Even if I keep it part throttle it clears up above 3,000rpm. The car pulls fine up top. It does not do it at all when the car is cold, only when I have been driving for about 15min. I replaced the Opti, plugs, wires, tried a diffrente coil, and hooked it up to a laptop. Everything looked fine but the long term fuel trims were not changing much, they were just staying right around 108. Any ideas?
GOaT Cheese Nov 7, 2006 10:33 PM
If you are running stock fuel injectors, ohm check them. It sounds like maybe an injector is loosing resistance, and spraying too much fuel.
Revelation Z28 Nov 7, 2006 10:37 PM
fuel filter
take the injectors off and clean them too.
put brake fluid in each one (one at a time)
hook a battery put to it
spray compressed air through it pushing the brake fluid out.
thecamarokid Nov 7, 2006 11:33 PM
Fuel filter is only like 6,000 miles old. I was thinking injectors so I will deffinatly try that. Thanks!
© 2026 MH Sub I, LLC dba Internet Brands
