crankshaft position sensor
Old Dec 3, 2006 | 05:24 PM
96RamAirTA's Avatar
Default crankshaft position sensor
i just had my check engine light read at autozone... any ways there is 2 things wrong with the crankshaft postion sensor...one had to do with a "perfomance reading" and the other just said it was messing up... but it sometimes the check engine lights stays on and other times its off... the after a while it will turn back on. so it you guys could help that would be great. also ive been hearing the winding noise coming for the back of my car and im not sure what it is. thanxs
Old Dec 3, 2006 | 08:42 PM
Black1997T/A's Avatar
Try cleaning then connector and make sure its tight, if not, Just replace it... they do go out.
