Help Backfiring
Old Jan 30, 2007 | 10:32 PM
str8rpn's Avatar
Default Help Backfiring
I have a 95 formula lt1....new lifters,springs,rockers,cam 230/236,longtubes
the car is an m6 and it backfires when letting off the clutch in first...it will pop as much as 5 times before the rpms raise enough
doesnt do this at higher speeds only starting off from a stop
also has a pcmforless tune
any ideas?
Old Jan 30, 2007 | 10:36 PM
1lo94's Avatar
had same problem your rocker arms are either to tight or to loose
Old Jan 30, 2007 | 10:38 PM
str8rpn's Avatar
what exactly happened in your situation?
was ur idleing a little screwed up too?
Old Jan 31, 2007 | 12:21 PM
str8rpn's Avatar
please help guys....any other ideas?
