LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Engine won't start (https://ls1tech.com/forums/lt1-lt4-modifications/661301-engine-wont-start.html)
deshazer Feb 18, 2007 07:53 PM
Engine won't start
97 LT1, sometimes will start and die in a couple of seconds and then will not start. Has gotten worse in past couple of days.
94strokedz Feb 18, 2007 07:56 PM
Check fuel pressure. Any codes??
deshazer Feb 18, 2007 07:58 PM
I have not checked codes, but I can smell the fuel as it turns over. I have replaced the fuel relay under the kick panel and the MAP sensor with no change.
redhot lt-1 Feb 18, 2007 07:59 PM
check opti if it stared skipping or cutting out before it got this bad
deshazer Feb 18, 2007 08:02 PM
When it started it would hesitate then run fine, and has even backfired a couple of times when it started getting bad.
© 2026 MH Sub I, LLC dba Internet Brands
