LS1 6 Speed. What's the difference? I see alot of ls1 6speed setups for sale on this forumn. What is the main difference from a complete ls1 6pseed setup to a lt1 6speed setup? Can I make a ls1 tranny work on a lt1 car? -Thanks |
well the clutches are different |
the front plate on the trans should be different to. LS1 are a internal slave/hydraulic throw out bearing. Where LT1's have the mount for the release fork. |
Bellhousing and Input/Output shafts. Tony. |
Well I guess putting a ls1 6 speed in a lt1 is way out of the question. If anyone has a lt1 6 speed set-up that is willing to trade for a th350 setup shoot me a pm. -Thanks |
Damn, I'd trade you my whole 355 M6 for your car. That's a sweet looking ride. Should be able to find some M6 LT1 parts on cz28.com |
throw out bearing is more expensive GM one runes about $200 or so. LS1 has a longer input shaft |
If you want to convert the ls1 to lt1 style you will need the lt1 input shaft,bellhousing,and front cover. |
| All times are GMT -5. The time now is 10:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
