o2's read low on scanmaster i noticed that my o2 sensor like to read pretty low on my scanmaster ever since i put the pacesetter long tubes on is this normal or do i need to replace them. they hang around .065 Mv for bout a second then go up about .9##. |
do you have a single wire o2 or a heated 4 wire one? it might be because your longer tubes allow cooling quicker and don't help as much with heating the o2 but this is easily fixed by upgrading to the 4 wire heated o2 sensor |
I have the heated four wire. |
where the 4 wires before the long tube? also did you have to do anything to the wires when you put in your tubes? |
Does it do that on both or just one? I've noticed my driver side will read less than 200 mv and it dumps a lot more fuel in on that side. If you are driving the car and they're showing low then I'd see about replacing them. |
Originally Posted by black_sunshine where the 4 wires before the long tube? also did you have to do anything to the wires when you put in your tubes? |
Did you ever figure this out. My car with scanmaster also seems to give weird low 02 readings sometimes at wot when it stores it. I have replaced fuel pump, fuel filter, fuel reg and flushed out injectors. Still same ,also see some knock retard that makes no sense either. |
| All times are GMT -5. The time now is 05:38 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
