LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Is there a difference between the 97 lt1's valve spring caps & (https://ls1tech.com/forums/lt1-lt4-modifications/683226-there-difference-between-97-lt1s-valve-spring-caps.html)
LTBANDIT Mar 25, 2007 09:55 PM
the lt4's valve spring caps... reason i ask is because i change valve springs and only recieved 8 caps... anyway i used calipers and measured the lt1 and lt4 caps and they were identical...
i have an lt1/lt4 rebuild book and the only cap part #'s it calls out are for 93-96 regular and lightwieght caps for aluminum heads and lt4 lightwieght caps...
did not mention a part number for the 97 lt1's...
does anyone know if they are different?
foggedz Mar 26, 2007 11:29 AM
Some shop books etc, only list the lt1 parts to 96. I believe this is because the LS1 came on the Vetts starting in 97.
© 2026 MH Sub I, LLC dba Internet Brands
