next mod?
What he said. Definitely gonna put you in the top of the RPM range quicker. However you have to think about things like does your cam need you to be that high and can your bearings take 6000+ rpm. With stock cam and stock bottom, you're not gonna need the top so much. However, it'll give you some grunt on the bottom end and you're definitely gonna be able to chirp the tires. If you plan on doing a big motor in the future, the 10 bolt won't last long but if this is a bolt on car, then I'd say 3.73's would be a great idea. Only problem is that gears aren't something to do yourself.
